Decide if you want to install the software by using a CD-ROM drive or by using a net image.
If you're using a CD-ROM drive, insert the Solaris 9 Software 1 of 2 SPARC Platform Edition CD
If you're using a net installation image, change directories to where the installation media is located, as in the following example. You might need to check with your network administrator for the location. The following command is an example.
% cd /net/install-svr/export/s9/sparc |
Boot the system.
If the system is new, out-of-the-box, turn on the system.
If you want to install or upgrade an existing system, shut down the system.
To boot from the local CD, type:
ok boot cdrom |
To boot from an install server on a network, type:
ok boot net |
The Solaris suninstall program begins.
If you are prompted, answer the system configuration questions.
If you preconfigured all of the system configuration information, the Solaris suninstall program does not prompt you to enter any configuration information.
If you did not preconfigure the system configuration information, use the “Worksheet for Installation” or the “Worksheet for Upgrading” to help you answer the system configuration questions.
Follow the instructions on the screen to install the Solaris software on the system.
If you are not installing a Solaris Flash archive, complete the installation. If you are upgrading or need to install additional software, proceed to Step 5.
When the Solaris suninstall program finishes installing the Solaris software, the system reboots automatically or prompts you to reboot manually.
After the installation is finished, installation logs are saved in a file. You can find the installation logs in the following directories:
/var/sadm/system/logs
/var/sadm/install/logs
If you are installing a Solaris Flash archive, continue.
On the Flash Archive Retrieval Method screen, select the location of the Solaris Flash archive.
The Solaris suninstall program installation prompts you to proceed, depending on the media you selected.
Type the information that you are prompted to enter.
Media Selected |
Prompt |
HTTP |
Specify the URL and proxy information that is needed to access the Solaris Flash archive. |
FTP |
Specify the FTP server and the path to the Solaris Flash archive. Specify the user and password information that allows you access to the FTP server. Specify any proxy information that is needed to access the FTP server. |
Network File System |
Specify the path to the network file system where the Solaris Flash archive is located. You can also specify the archive file name. |
Local file |
Specify the path to the local file system where the Solaris Flash archive is located. |
Local tape |
Specify the local tape device and the position on the tape where the Solaris Flash archive is located. |
Local device |
Specify the local device, the path to the Solaris Flash archive, and the type of file system on which the Solaris Flash archive is located. |
On the Flash Archive Selection screen, you can install an additional Solaris Flash archive by selecting New. If you do not want to install additional archives, press Continue to complete the installation.
If you are upgrading the Solaris software, you might need to correct some local modifications that were not preserved. For detailed instructions, refer to “Solaris suninstall Program Post-Upgrade Task”.
(Optional) To install additional software, refer to System Administration Guide: Basic Administration.
