SPARC: You cannot use a system that is running a SunOS version that was released prior to the Solaris 2.3 release.
This procedure assumes that the system is running the Volume Manager. If you are not using the Volume Manager to manage media, refer to System Administration Guide: Basic Administration for detailed information about managing removable media without the Volume Manager.
On the SPARC system that is to become the install server, become superuser.
The system must include a DVD-ROM drive and be part of the site's network and name service. If you use a name service, the system must already be in a service, such as NIS, NIS+, DNS, or LDAP. If you do not use a name service, you must distribute information about this system by following your site's policies.
Insert the Solaris 9 DVD in the SPARC system's drive.
Create a directory to contain the DVD image.
# mkdir -p install_dir_path |
Change to the Tools directory on the mounted disc.
For SPARC DVD media, type:
# cd /cdrom/cdrom0/s0/Solaris_9/Tools |
For IA DVD media, type:
# cd /cdrom/cdrom0/Solaris_9/Tools |
Copy the DVD image in the drive to the install server's hard disk.
# ./setup_install_server install_dir_path |
install_dir_path |
Specifies the directory where the DVD image is to be copied |
The setup_install_server command indicates whether you have enough disk space available for the Solaris 9 Software disc images. To determine available disk space, use the df -kl command.
Decide if you need to make the install server available for mounting.
If the install server is on the same subnet as the system to be installed or you are using DHCP, you do not need to create a boot server. Proceed to Step 7.
If the install server is not on the same subnet as the system to be installed and you are not using DHCP, complete the following steps.
Verify that the path to the install server's image is shared appropriately.
# share | grep install_dir_path |
install_dir_path |
Specifies the path to the installation image where the DVD image was copied |
If the path to the install server's directory is displayed and anon=0 is displayed in the options, proceed to Step 7.
If the path to the install server's directory is not displayed or you do not have anon=0 in the options, continue.
Make the install server available to the boot server by adding this entry to the /etc/dfs/dfstab file.
share -F nfs -o ro,anon=0 -d "install server directory" install_dir_path |
Make sure that the install server's directory path is correctly shared.
# ps -ef | grep nfsd |
If nfsd daemon is not running, start it.
# /etc/init.d/nfs.server start |
If nfsd daemon is running, share the install server.
# shareall |
Change directories to root (/).
# cd / |
Eject the Solaris 9 DVD.
Decide if you want to patch the files that are located in the miniroot (/install_dir_path/Solaris_9/Tools/Boot) on the net install image that was created by setup_install_server. Patching a file might be necessary if a boot image has problems.
If no, continue.
If yes, use the patchadd -C command to patch the files that are located in the miniroot.
Don't use the patchadd -C unless you have read the Patch Readme instructions or have contacted your local Sun support office.
Decide if you need to create a boot server.
If you are using DHCP or the install server is on the same subnet as the system to be installed, you do not need to create a boot server. Proceed to “Adding Systems to Be Installed From the Network With a DVD Image”.
If you are not using DHCP and the install server and the client is on a different subnet, you must create a boot server. Proceed to “Creating a Boot Server on a Subnet With a DVD Image”.
The following example illustrates how to create an install server by copying the Solaris 9 DVD to the install server's /export/home/s9dvdsparc directory:
# mkdir -p /export/home/s9dvdsparc # cd /cdrom/cdrom0/s0/Solaris_9/Tools # ./setup_install_server /export/home/s9dvdsparc |
If you need a separate boot server, add these steps:
Add the following path to the /etc/dfs/dfstab file:
share -F nfs -o ro,anon=0 -d "install server directory" /export/home/s9dvdsparc |
Check if the nfsd daemon is running. If nfsd daemon is not running, start it and share it.
# ps -ef | grep nfsd # /etc/init.d/nfs.server start # shareall # cd / |
The following example illustrates how to create an install server by copying the Solaris 9 DVD to the install server's /export/home/s9dvdia directory:
# mkdir -p /export/home/s9dvdia # cd /cdrom/cdrom0/Solaris_9/Tools # ./setup_install_server /export/home/s9dvdia |
share -F nfs -o ro,anon=0 -d "install server directory" /export/home/s9dvdia |
