Use this procedure to create an IA install server on a SPARC system with IA CD media. You need the following:
A SPARC system
An IA system with a CD-ROM drive
A set of CDs for the remote IA system
Solaris 9 Software 1 of 2 Intel Platform Edition CD
Solaris 9 Software 2 of 2 Intel Platform Edition CD
Solaris 9 Intel Platform Edition Languages CD
Solaris 9 Intel Platform Edition Installation CD
This procedure assumes that the system is running the Volume Manager. If you are not using the Volume Manager to manage media, refer to System Administration Guide: Basic Administration for detailed information about managing removable media without the Volume Manager.
In this procedure, SPARC system is the SPARC system that is to be the install server and remote IA system is the remote IA system to be used with the IA CD media.
On the remote IA system, become superuser.
The system must include a CD-ROM drive and be part of the site's network and name service. If you use a name service, the system must also be in the NIS, NIS+, DNS, or LDAP name service. If you do not use a name service, you must distribute information about this system by following your site's policies.
On the remote IA system, insert the Solaris 9 Software 1 of 2 Intel Platform Edition CD into the system's drive.
On the remote IA system, add the following entries to the /etc/dfs/dfstab file.
share -F nfs -o ro,anon=0 /cdrom/cdrom0/s0 share -F nfs -o ro,anon=0 /cdrom/cdrom0/s2 |
On the remote IA system, start the NFS daemon.
remote IA system# /etc/init.d/nfs.server start |
On the remote IA system, verify that the CD is available to other systems by using the share command.
remote IA system# share - /cdrom/sol_9_ia/s0 ro,anon=0 " " - /cdrom/sol_9_ia/s2 ro,anon=0 " " |
On the SPARC system that is to be the IA install server, become superuser.
On the SPARC system, access the IA CD by creating two directories for the appropriate mount points, one for the miniroot and one for the product.
SPARC system# mkdir directory_name_s0 |
SPARC system# mkdir directory_name_s2 |
directory_name_s0 |
Is the name of the directory to contain the miniroot from slice 0 |
directory_name_s2 |
Is the name of the directory to contain the product from slice 2 |
On the SPARC system, mount the remote IA CD image.
SPARC system# mount remote_IA_system_name:/cdrom/sol_9_ia/s0 directory_name_s0 |
SPARC system# mount remote_IA_system_name:/cdrom/sol_9_ia/s2 directory_name_s2 |
On the SPARC system, change to the Tools directory on the mounted disc:
SPARC system# cd /directory_name_s2/Solaris_9/Tools |
On the SPARC system, copy the disc in the drive to the install server's hard disk in the directory you've created by using the setup_install_server command:
SPARC system# ./setup_install_server -t directory_name_s0 install_dir_path |
-t |
Specifies the path to a boot image if you want to use a boot image other than the one in the Tools directory on the Solaris 9 Software 2 of 2 CD. |
directory_name_s0 |
Is the name of the directory that contains the miniroot from slice 0. |
install_dir_path |
Specifies the directory where the disc image is to be copied. The directory must be empty. |
The setup_install_server command indicates whether you have enough disk space available for the Solaris 9 Software disc images. To determine available disk space, use the df -kl command.
On the SPARC system, change to the top directory.
SPARC system# cd / |
On the SPARC system, unmount both directories.
SPARC system# unmount directory_name_s0 |
SPARC system# unmount directory_name_s2 |
On the IA system, unshare both CD-ROM slices.
remote IA system# unshare /cdrom/sol_9ia/s0 |
remote IA system# unshare /cdrom/sol_9ia/s2 |
On the IA system, eject the Solaris 9 Software 1 of 2 Intel Platform Edition CD.
Insert the Solaris 9 Software 2 of 2 Intel Platform Edition CD into the SPARC system's CD-ROM drive.
On the SPARC system, change to the Tools directory on the mounted CD:
SPARC system# cd /cdrom/cdrom0/Solaris_9/Tools |
On the SPARC system, copy the CD to the install server's hard disk:
SPARC system# ./add_to_install_server install_dir_path |
install_dir_path |
Specifies the directory where the CD image is to be copied |
Eject the Solaris 9 Software 2 of 2 Intel Platform Edition CD.
On the SPARC system, insert the Solaris 9 Intel Platform Edition Languages CD into the SPARC system's CD-ROM drive and mount the CD.
SPARC system# cd /cdrom/cdrom0/Tools |
install_dir_path |
Decide if you want to enable users to use the Solaris Web Start installation method to boot a system and install the Solaris 9 software from a network.
If no, eject the Solaris 9 Intel Platform Edition Languages CD and go to Step 30.
If yes, eject the Solaris 9 Intel Platform Edition Languages CD and continue.
On the remote IA system, insert the Solaris 9 Intel Platform Edition Installation CD into the IA system's CD-ROM drive.
On the remote IA system, add the following entry to the /etc/dfs/dfstab file.
On the remote IA system, verify that the CD is available to other systems:
remote IA system# share - /cdrom/multi_sol_9_ia/s0 ro,anon=0 " " - /cdrom/multi_sol_9_ia/s2 ro,anon=0 " " |
On the SPARC system, mount the slices on the CD.
SPARC system# mount remote_IA_system_name:/cdrom/multi_sol_9_ia/s0 directory_name_s0 SPARC system# mount remote_IA_system_name:/cdrom/multi_sol_9_ia/s2 directory_name_s2 |
On the SPARC system, change to the directory that contains modify_install_server on the mounted CD:
SPARC system# cd directory_name_s2 |
Copy the Solaris Web Start interface software to the install server:
SPARC system# ./modify_install_server -p install_dir_path directory_name_s0 |
-p |
Preserves the existing image's miniroot in install_dir_path/Solaris_9/Tools/Boot.orig |
install_dir_path |
Specifies the directory where the Solaris Web Start interface is to be copied |
directory_name_s0 |
Name of the directory to contain the miniroot from slice 0 |
Decide if you want to patch the files that are located in the miniroot (Solaris_9/Tools/Boot) on the net install image that was created by setup_install_server.
If no, go to the next step.
If yes, use the patchadd -C command to patch the files that are located in the miniroot.
Don't use the patchadd -C unless you have read the Patch Readme instructions or have contacted your local Sun support office.
Decide if you need to create a boot server.
If the install server is on the same subnet as the system to be installed or you are using DHCP, you do not need to create a boot server. See “Adding Systems to Be Installed From the Network With a CD Image”.
If the install server is not on the same subnet as the system to be installed and you are not using DHCP, you must create a boot server. For detailed instructions on how to create a boot server, refer to “To Create a Boot Server on a Subnet With a CD Image”.
The following example illustrates how to create an IA install server on a SPARC system that is named rosemary. The following IA CDs are copied from a remote IA system that is named tadpole to the SPARC install server's /export/home/s9cdia directory.
Solaris 9 Installation Multilingual Intel Platform Edition CD
On the remote IA system:
tadpole (remote IA system)# share -F nfs -o ro,anon=0 /cdrom/cdrom0/s0 tadpole (remote IA system)# share -F nfs -o ro,anon=0 /cdrom/cdrom0/s2 tadpole (remote IA system)# /etc/init.d/nfs.server start |
On the SPARC system:
rosemary (SPARC system)# mkdir /iaS0 rosemary (SPARC system)# mkdir /iaS2 rosemary (SPARC system)# mount tadpole:/cdrom/sol_9_ia/s0 /iaS0 rosemary (SPARC system)# mount tadpole:/cdrom/sol_9_ia/s0 /iaS2 rosemary (SPARC system)# cd /iaS2/Solaris_9/Tools rosemary (SPARC system)# ./setup_install_server -t /iaS0 /export/home/s9cdia rosemary (SPARC system)# cd / rosemary (SPARC system)# unmount /iaS0 rosemary (SPARC system)# unmount /iaS2 tadpole (remote IA system) unshare /cdrom/cdrom0/s0 tadpole (remote IA system) unshare /cdrom/cdrom0/s2 rosemary (SPARC system)# cd /cdrom/cdrom0/Solaris_9/Tools rosemary (SPARC system)# ./add_to_install_server /export/home/s9cdia rosemary (SPARC system)# cd /cdrom/cdrom0/sol_9_lang_ia/Tools rosemary (SPARC system)# ./add_to_install_server /export/home/s9cdia |
rosemary (SPARC system)# mount remote_IA_system_name:/cdrom/sol_9_ia /iaS0 rosemary (SPARC system)# mount remote_IA_system_name:/cdrom/sol_9_ia /iaS2 rosemary (SPARC system)# cd /iaS2 rosemary (SPARC system)# ./modify_install_server -p /export/home/s9cdia /iaS0 |
In this example, each CD is inserted and automatically mounted before each of the commands. After each command, the CD is removed.
