boot_device device eeprom |
boot_device designates the device where the JumpStart program is to install the root (/) file system and the system's boot device.
If you do not specify the boot_device keyword in a profile, the following boot_device keyword is specified by default during the installation: boot_device any update.
device – Use one of the following values.
SPARC: cwtxdysz or cxdysz – The disk slice where the JumpStart program places the root (/) file system, for example, c0t0d0s0.
IA: cwtxdy or cxdy – The disk where the JumpStart program places the root (/) file system, for example, c0d0.
existing – The JumpStart program places the root (/) file system on the system's existing boot device.
any – The JumpStart program chooses where to place the root (/) file system. The JumpStart program attempts to use the system's existing boot device. The JumpStart program might choose a different boot device if necessary.
eeprom – Choose to update or preserve the system's EEPROM.
SPARC: Choose if you want to update or preserve the system's EEPROM to the specified boot device.
IA: You must specify the preserve value.
update – The JumpStart program updates the system's EEPROM to the specified boot device so that the installed system automatically boots from it.
preserve – The boot device value in the system's EEPROM is not changed. If you specify a new boot device without changing the system's EEPROM, you need to change the system's EEPROM manually so it can automatically boot from the new boot device.
SPARC: On SPARC systems, the eeprom value also allows you to update the system's EEPROM if you change the system's current boot device. By updating the system's EEPROM, the system can automatically boot from the new boot device.
Example:
boot_device c0t0d0s2 update
boot_device must match any filesys keywords that specify the root (/) file system and the root_device keyword, if specified.
