Solaris 9 Installation Guide
To Allow All Systems Access to the Profile Server
When you create a profile server, you must ensure that systems can access the JumpStart directory on the profile server during a custom JumpStart installation. Use one of the following ways to ensure access:
Note -
The following procedure is not necessary if you save the JumpStart directory on a diskette or if you specify the location of the profile server when you boot the system.
The following procedure is valid only if you store network installation information in the /etc/bootparams file. You can also store network installation information in one of the following places:
  1. On the install or boot server, log in as superuser.
  2. Use a text editor to open /etc/bootparams.
  3. Add this entry.
    * install_config=server:jumpstart_dir_path
    A wildcard character that specifies that all systems have access
    server
    The host name of the profile server where the JumpStart directory is located
    jumpstart_dir_path
    The absolute path of the JumpStart directory
    For example, the following entry allows all systems to access the /jumpstart directory on the profile server that is named sherlock:
    * install_config=sherlock:/jumpstart
    Caution - Caution -
    Use of this procedure might produce the following error message when an install client is booted:
    WARNING: getfile: RPC failed: error 5: (RPC Timed out).
    “Booting From the Network, Error Messages” contains details about this error message.
    All systems can now access the profile server.
