This procedure assumes that the system is running Volume Manager. If you are not using Volume Manager to manage diskettes, CDs, and DVDs, refer to System Administration Guide: Basic Administration for detailed information about managing removable media without Volume Manager.
Log in as superuser on an IA system to which a diskette drive is attached.
Insert the Solaris 9 Device Configuration Assistant Intel Platform Edition diskette into the diskette drive (usually drive A). You use this diskette as the profile diskette.
You can access the boot diskette software by downloading and copying the software to a diskette from the Solaris Developer Connection at http://soldc.sun.com/support/drivers/dcs_diskettes.
# volcheck |
Copy the image of the Solaris 9 Device Configuration Assistant to the system's hard disk.
# dd if=/vol/dev/aliases/floppy0 of=boot_image |
In the command, boot_image is the name of the file into which you want to copy the image of the Solaris 9 Device Configuration Assistant. You can specify an absolute path name.
For example, the following command copies the boot diskette to a file that is named boot_save:
dd if=/vol/dev/aliases/floppy0 of=boot_save |
Eject the diskette by clicking Eject Disk in the File Manager window or by typing eject floppy on the command line.
In the Removable Media Manager dialog box, click OK.
Manually eject the Solaris 9 Device Configuration Assistant Intel Platform Edition diskette.
Insert a blank diskette or a diskette that can be overwritten into the diskette drive.
# volcheck |
Formatting erases all data on the diskette.
# fdformat -d -U |
Copy the Solaris 9 Device Configuration Assistant image from the system's hard disk to the formatted diskette.
# dd if=boot_image of=/vol/dev/aliases/floppy0 |
In the command, boot_image is the name of the file where you want to copy the image of the Solaris 9 Device Configuration Assistant. You can specify an absolute path name.
Determine if you want to copy examples of custom JumpStart files to your JumpStart directory.
If no, go to Step 15.
If yes, use the following decision table to determine what to do next.
Copy the example custom JumpStart files into the JumpStart directory on the profile diskette.
# cp -r media_path/Solaris_9/Misc/jumpstart_sample/* jumpstart_dir_path |
media_path |
The path to the CD, DVD, or image on the local disk |
The path to the profile diskette where you want to place the example custom JumpStart files |
You must place all custom JumpStart installation files in the root (/) directory on the profile diskette.
For example, the following command copies the contents of jumpstart_sample on the Solaris 9 Software 1 of 2 Intel Platform Edition CD to the root (/) directory on a profile diskette that is named scrap:
cp -r /cdrom/sol_9_ia/s2/Solaris_9/Misc/jumpstart_sample/* /floppy/scrap |
Update the example JumpStart files on the profile diskette so that the files work in your environment.
Ensure that root owns the JumpStart directory and that permissions are set to 755.
Manually eject the diskette.
You have completed the creation of a profile diskette. Now you can update the rules file and create profiles on the profile diskette to perform custom JumpStart installations. To continue, go to “Creating the rules File”.
