Solaris 9 Installation Guide
To Display the Status of All Boot Environments (Character Interface)
  1. From the main menu, select Status.
    A table that is similar to the following is displayed:
    BE_name             Complete  Active  ActiveOnReboot  CopyStatus
    disk_a_S7            yes       yes     yes              -
    disk_b_S7database    yes       no      no              COPYING
    disk_b_S8            no        no      no               -
    Note -
    In this example, you could not perform copy, rename, or upgrade operations on disk_b_S8 because it is not complete, nor on disk_b_S7database, because a live upgrade operation is in progress.
