Solaris 9 Installation Guide
To Correct Local Modifications After Upgrading
When you upgrade, the Solaris Web Start program merges local software modifications of the existing system with the new Solaris software. However, in some situations, merging is not possible. After you finish upgrading a system, you might need to correct some local modifications that were not preserved.
Caution - Caution -
Your system might not boot if you do not correct the local modifications that were not preserved.
  1. Review the contents of the following file to determine whether you need to correct local modifications that the Solaris Web Start program could not preserve.
    /a/var/sadm/system/data/upgrade_cleanup
  2. Correct any local modifications that were not preserved.
  3. Reboot the system.
    # reboot
