The /etc/inet/ike/publickeys directory contains the public part of a public-private key pair and its certificate in files, or “slots”. The /etc/inet/ike directory is protected at 0755. You use the ikecert certdb command to populate the directory.
The files contain, in encoded form, the X.509 distinguished name of a certificate that was generated on another system. If you are using self-signed certificates, you use the certificate that you receive from the administrator of the communicating system as input to the command. If you are using certificates from a PKI, you install two pieces of keying material from the PKI into this database. You install a certificate that is based on material that you sent to the PKI. You also install a CA from the PKI.
