This section describes the essential keyboard shortcuts to enable you to navigate the desktop from the keyboard.
You can customize some of the keyboard shortcuts that are described in this chapter. The text indicates the shortcuts that you can customize. See Customizing Your Keyboard Shortcuts for information about how to customize keyboard shortcuts.
The following table lists the essential keyboard shortcuts that you can use to navigate the desktop. The keyboard shortcuts that you use to navigate specific desktop elements and controls are described in the appropriate sections of this chapter.
Keys |
Function |
Tab |
Give focus to the next desktop element or control. |
Shift+Tab |
Reverse the navigation direction and give focus to the previous desktop element or control. In general, the Shift key reverses the navigation direction. |
Ctrl+Tab |
If the Tab key has a specific purpose in a control, press Ctrl+Tab to give focus to the next element or control. For example, if you press Tab in a text box, the system inserts a tab space. To give focus to the previous element or control, press Shift+Ctrl+Tab. |
arrow keys |
Navigate within a desktop element or control. |
spacebar |
Activate the element or control that has focus. For example, if the current control is a button, this action is the equivalent of clicking on the button with a mouse. |
Esc |
Close a window, menu, or drawer. |
The following table lists the keyboard shortcuts that you can use from any part of the desktop.
Keys |
Function |
Alt+F1 |
Open the Main Menu at the location of your mouse pointer. You can customize this keyboard shortcut. |
Alt+F2 |
Open the Run Program dialog. You can customize this keyboard shortcut. |
Print Screen |
Take a screenshot of the entire screen. You can customize this keyboard shortcut. |
Alt+Print Screen |
Take a screenshot of the window that currently has focus. You can customize this keyboard shortcut. |
F1 |
If the focused desktop element is an application window or dialog, this keyboard shortcut opens the online help for the application. |
Ctrl+ F1 |
If the focused desktop element is a panel or application window, this keyboard shortcut switches the display of tooltips for the window or panel objects on and off. |
Shift+ F10 |
Open a popup menu for the desktop element that has focus, if a popup menu exists. |
