The following table describes the keyboard shortcuts that enable you to navigate the file manager side pane in general.
Keys |
Function |
F6 |
Switch focus between the side pane and the view pane. |
Shift+ F10 |
Open the side pane popup menu. |
Shift+Tab |
Switch the focus from the tab contents to the tab name. |
arrow keys |
Give focus to the next or previous tab name, when a tab name has focus. |
spacebar |
Display or hide the tab that has focus. The tab name remains in focus. |
Tab |
Move the focus from the tab name to the tab contents. |
The following table describes the keyboard shortcuts that enable you to navigate the History tab in the side pane.
Keys |
Function |
arrow keys |
Give focus to the next or previous file or folder in the history list. |
spacebar |
Open the file or folder that has focus in the history list. |
For information about how to navigate the Notes tab of the file manager side pane, see To Navigate Text Boxes for information about how to navigate multi-line text boxes.
For information about how to navigate the Tree tab of the file manager side pane, see To Navigate Trees.
