GNOME 2.0 Desktop for the Solaris Operating Environment Accessibility Guide
To Navigate Menus
The following table lists the keyboard shortcuts that you can use to navigate menus.
Keys
Function
up arrow and down arrow
Give focus to the next or previous menu item on a menu.
right arrow
If the menu item that has focus is a submenu, open the submenu and give focus to the first menu item on the submenu.
If the menu item that has focus is not a submenu, open the next menu on the menubar.
left arrow
If the menu item that has focus is a submenu item, switch the focus back to the submenu.
If the menu item that has focus is not a submenu item, open the previous menu on the menubar.
Return
Select the focused menu item and close the open menus.
access key
Select the menu item that is associated with the access key and close the open menus.
spacebar
Select the focused menu item and close the open menus except when the menu item is a check box or radio button. If the menu item is a check box or radio button, the menu does not close.
Esc
Close the open menus.
