GNOME 2.0 Desktop for the Solaris Operating Environment Accessibility Guide
To Navigate Lists
The following table lists the keyboard shortcuts that you can use to navigate multi-column lists when a column header has focus.
Keys
Function
left arrow or right arrow
Give focus to the previous or next column header.
spacebar
Activate the header. This action usually sorts the list by the column header.
Tab
Give focus to the list contents.
The following table lists the keyboard shortcuts that you can use to navigate lists when the contents of the list has focus.
Keys
Function
arrow keys
Select the next or previous row or column.
Page Up
Select the top row of the list contents that are in view. Press Page Up again to select the top row of the previous view.
Page Down
Select the bottom row of the list contents that are in view. Press Page Down again to select the bottom row of the next view.
Home
Select the first row in the list.
End
Select the last row in the list.
Shift+arrow keys
For lists that support multiline selections, add the next or previous row or column to the current selection.
For lists that only allow single line selections, select the next or previous row or column.
Shift+Page Up
Select all the rows between the current selection and the top row of the view.
Shift+Page Down
Select all the rows between the current selection and the bottom row of the view.
Shift+Home
Select all the rows between the current selection and the first row in the list.
Shift+End
Select all the rows between the current selection and the last row in the list.
Ctrl+arrow keys
Give focus to the next row or column but do not extend the selection.
Ctrl+Page Up
Give focus to the top row in the view but do not extend the selection.
Ctrl+Page Down
Give focus to the bottom row in the view but do not extend the selection.
Ctrl+Home
Give focus to the first row in the list but do not extend the selection.
Ctrl+End
Give focus to the last row in the list but do not extend the selection.
Ctrl+spacebar
Add the focused row to the selection or remove the focused row from the selection.
spacebar
If the selected item is a text box, this key enables you to edit the item.
If the selected item is a check box, this key enables you to select or deselect the check box.
Return
Activate the item.
Ctrl+A
For lists that support multiline selections, select all rows in the list.
Shift+ Tab
Give focus to the column header, if applicable.
