A drawer is a collapsible extension of a panel. The following table lists the keyboard shortcuts that you can use to navigate into and out of drawers. When you open a drawer, you can navigate the contents of the drawer in the same way as you navigate a panel. See Navigating Panels for information about how to navigate a panel.
Keys |
Function |
spacebar |
Open or close the drawer that has focus. |
arrow keys |
Navigate into the drawer that has focus. |
Esc |
Close the drawer and give focus to the drawer object on the panel. |
Shift+Esc |
Give focus to the drawer object on the panel and leave the drawer open. |
