When the ypserv process crashes almost immediately, and does not stay up even with repeated activations, the debug process is virtually identical to that described in ypbind Crashes. Check for the existence of the rpcbind daemon as follows.
ypserver% ps -e | grep rpcbind
Reboot the server if you do not find the daemon. Otherwise, if the daemon is running, type the following and look for similar output.
% rpcinfo -p ypserver
% program vers proto port service 100000 4 tcp 111 portmapper 100000 3 tcp 111 portmapper 100068 2 udp 32813 cmsd ... 100007 1 tcp 34900 ypbind 100004 2 udp 731 ypserv 100004 1 udp 731 ypserv 100004 1 tcp 732 ypserv 100004 2 tcp 32772 ypserv |
Your machine might have different port numbers. The four entries representing the ypserv process are the following.
If there are no entries, and ypserv is unable to register its services with rpcbind, reboot the machine. If there are entries, de-register the service from rpcbind before restarting ypserv. To de-register the service from rpcbind, on the server type the following.
# rpcinfo -d number 1
# rpcinfo -d number 2
where number is the ID number reported by rpcinfo (100004, in the example above).
