System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Using makedbm to Modify a Non-Default Map
There are two different
methods for using makedbm to modify maps if you do not
have an input file:
Redirect the makedbm -u
output to a temporary file, modify the file, then use the modified file as
input to makedbm.
Have the output of makedbm -u
operated on within a pipeline that feeds into makedbm.
This is appropriate if you can update the disassembled map with either awk, sed, or a cat append.
- © 2010, Oracle Corporation and/or its affiliates
