The LDAP servers must be configured to support the revised RFC 2307.
The nisSchema OID is 1.3.6.1.1. The RFC 2307 Attributes are the following.
( nisSchema.1.0 NAME 'uidNumber'
DESC 'An integer uniquely identifying a user in an
administrative domain'
EQUALITY integerMatch SYNTAX 'INTEGER' SINGLE-VALUE )
( nisSchema.1.1 NAME 'gidNumber'
DESC 'An integer uniquely identifying a group in an
( nisSchema.1.2 NAME 'gecos'
DESC 'The GECOS field; the common name'
EQUALITY caseIgnoreIA5Match
SUBSTRINGS caseIgnoreIA5SubstringsMatch
SYNTAX 'IA5String' SINGLE-VALUE )
( nisSchema.1.3 NAME 'homeDirectory'
DESC 'The absolute path to the home directory'
EQUALITY caseExactIA5Match
( nisSchema.1.4 NAME 'loginShell'
DESC 'The path to the login shell'
( nisSchema.1.5 NAME 'shadowLastChange'
( nisSchema.1.6 NAME 'shadowMin'
( nisSchema.1.7 NAME 'shadowMax'
( nisSchema.1.8 NAME 'shadowWarning'
( nisSchema.1.9 NAME 'shadowInactive'
( nisSchema.1.10 NAME 'shadowExpire'
( nisSchema.1.11 NAME 'shadowFlag'
( nisSchema.1.12 NAME 'memberUid'
SUBSTRINGS caseExactIA5SubstringsMatch
SYNTAX 'IA5String' )
( nisSchema.1.13 NAME 'memberNisNetgroup'
( nisSchema.1.14 NAME 'nisNetgroupTriple'
DESC 'Netgroup triple'
SYNTAX 'nisNetgroupTripleSyntax' )
( nisSchema.1.15 NAME 'ipServicePort'
( nisSchema.1.16 NAME 'ipServiceProtocol'
SUP name )
( nisSchema.1.17 NAME 'ipProtocolNumber'
( nisSchema.1.18 NAME 'oncRpcNumber'
( nisSchema.1.19 NAME 'ipHostNumber'
DESC 'IP address as a dotted decimal, eg. 192.168.1.1
omitting leading zeros'
SUP name )
( nisSchema.1.20 NAME 'ipNetworkNumber'
DESC 'IP network as a dotted decimal, eg. 192.168,
SUP name SINGLE-VALUE )
( nisSchema.1.21 NAME 'ipNetmaskNumber'
DESC 'IP netmask as a dotted decimal, eg. 255.255.255.0,
SYNTAX 'IA5String{128}' SINGLE-VALUE )
( nisSchema.1.22 NAME 'macAddress'
DESC 'MAC address in maximal, colon separated hex
notation, eg. 00:00:92:90:ee:e2'
SYNTAX 'IA5String{128}' )
( nisSchema.1.23 NAME 'bootParameter'
DESC 'rpc.bootparamd parameter'
SYNTAX 'bootParameterSyntax' )
( nisSchema.1.24 NAME 'bootFile'
DESC 'Boot image name'
( nisSchema.1.26 NAME 'nisMapName'
SUP name )
( nisSchema.1.27 NAME 'nisMapEntry'
SYNTAX 'IA5String{1024}' SINGLE-VALUE )
( nisSchema.1.28 NAME 'nisPublicKey'
DESC 'NIS public key'
SYNTAX 'nisPublicKeySyntax' )
( nisSchema.1.29 NAME 'nisSecretKey'
DESC 'NIS secret key'
SYNTAX 'nisSecretKeySyntax' )
( nisSchema.1.30 NAME 'nisDomain'
DESC 'NIS domain'
( nisSchema.1.31 NAME 'automountMapName'
DESC 'automount Map Name'
SUBSTR caseExactIA5SubstringsMatch
SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 SINGLE-VALUE )
( nisSchema.1.32 NAME 'automountKey'
DESC 'Automount Key value'
( nisSchema.1.33 NAME 'automountInformation'
DESC 'Automount information'
The nisSchema OID is 1.3.6.1.1. The RFC 2307 objectClasses are the following.
( nisSchema.2.0 NAME 'posixAccount' SUP top AUXILIARY
DESC 'Abstraction of an account with POSIX attributes'
MUST ( cn $ uid $ uidNumber $ gidNumber $ homeDirectory )
MAY ( userPassword $ loginShell $ gecos $ description ) )
( nisSchema.2.1 NAME 'shadowAccount' SUP top AUXILIARY
DESC 'Additional attributes for shadow passwords'
MUST uid
MAY ( userPassword $ shadowLastChange $ shadowMin
shadowMax $ shadowWarning $ shadowInactive $
shadowExpire $ shadowFlag $ description ) )
( nisSchema.2.2 NAME 'posixGroup' SUP top STRUCTURAL
DESC 'Abstraction of a group of accounts'
MUST ( cn $ gidNumber )
MAY ( userPassword $ memberUid $ description ) )
( nisSchema.2.3 NAME 'ipService' SUP top STRUCTURAL
DESC 'Abstraction an Internet Protocol service.
Maps an IP port and protocol (such as tcp or udp)
to one or more names; the distinguished value of
the cn attribute denotes the service's canonical
name'
MUST ( cn $ ipServicePort $ ipServiceProtocol )
MAY ( description ) )
( nisSchema.2.4 NAME 'ipProtocol' SUP top STRUCTURAL
DESC 'Abstraction of an IP protocol. Maps a protocol number
to one or more names. The distinguished value of the cn
attribute denotes the protocol's canonical name'
MUST ( cn $ ipProtocolNumber )
MAY description )
( nisSchema.2.5 NAME 'oncRpc' SUP top STRUCTURAL
DESC 'Abstraction of an Open Network Computing (ONC)
[RFC1057] Remote Procedure Call (RPC) binding.
This class maps an ONC RPC number to a name.
The distinguished value of the cn attribute denotes
the RPC service's canonical name'
MUST ( cn $ oncRpcNumber $ description )
MAY description )
( nisSchema.2.6 NAME 'ipHost' SUP top AUXILIARY
DESC 'Abstraction of a host, an IP device. The distinguished
value of the cn attribute denotes the host's canonical
name. Device SHOULD be used as a structural class'
MUST ( cn $ ipHostNumber )
MAY ( l $ description $ manager $ userPassword ) )
( nisSchema.2.7 NAME 'ipNetwork' SUP top STRUCTURAL
DESC 'Abstraction of a network. The distinguished value of
the cn attribute denotes the network's canonical name'
MUST ipNetworkNumber
MAY ( cn $ ipNetmaskNumber $ l $ description $ manager ) )
( nisSchema.2.8 NAME 'nisNetgroup' SUP top STRUCTURAL
DESC 'Abstraction of a netgroup. May refer to other netgroups'
MUST cn
MAY ( nisNetgroupTriple $ memberNisNetgroup $ description ) )
( nisSchema.2.9 NAME 'nisMap' SUP top STRUCTURAL
DESC 'A generic abstraction of a NIS map'
MUST nisMapName
MAY description )
( nisSchema.2.10 NAME 'nisObject' SUP top STRUCTURAL
DESC 'An entry in a NIS map'
MUST ( cn $ nisMapEntry $ nisMapName )
MAY description )
( nisSchema.2.11 NAME 'ieee802Device' SUP top AUXILIARY
DESC 'A device with a MAC address; device SHOULD be
MAY macAddress )
( nisSchema.2.12 NAME 'bootableDevice' SUP top AUXILIARY
DESC 'A device with boot parameters; device SHOULD be
MAY ( bootFile $ bootParameter ) )
( nisSchema.2.14 NAME 'nisKeyObject' SUP top AUXILIARY
DESC 'An object with a public and secret key'
MUST ( cn $ nisPublicKey $ nisSecretKey )
MAY ( uidNumber $ description ) )
( nisSchema.2.15 NAME 'nisDomainObject' SUP top AUXILIARY
DESC 'Associates a NIS domain with a naming context'
MUST nisDomain )
( nisSchema.2.16 NAME 'automountMap' SUP top STRUCTURAL
MUST ( automountMapName )
MAY description )
( nisSchema.2.17 NAME 'automount' SUP top STRUCTURAL
MUST ( automountKey $ automountInformation )
MAY description )
