You can configure Sun ONE Directory Server 5.1 software using one of the four different configuration methods provided in the setup program.
Express configuration
Use this if you are installing for the purposes of evaluating or testing Sun ONE Directory Server 5.1. See Using Express Configuration.
Typical configuration
Use this if you are performing a normal install of Sun ONE Directory Server 5.1. See Using Typical Configuration.
Custom configuration
In Sun ONE Directory Server 5.1, the custom configuration process is very similar to the typical configuration process. The main difference is that the custom configuration process will allow you to import an LDIF file to initialize the user directory database that is created by default.
Beyond determining which type of configuration process you will use, the process for configuring Sun ONE Directory Server 5.1 is as follows:
Plan your directory service. By planning your directory tree in advance, you can design a service that is easy to manage and easy to scale as your organization grows. For guidance on planning your directory service, refer to the Sun ONE Directory Server 5.1 Deployment Guide.
Configure your Sun ONE Directory Server 5.1 as described in this chapter.
Create the directory suffixes and databases. You do not have to populate your directory now; however, you should create the basic structure for your tree, including all major roots and branch points. For information about the different methods of creating a directory entry, refer to the Sun ONE Directory Server 5.1 Administrator's Guide.
Create additional Sun ONE Directory Server 5.1 instances and set up replication agreements between your Sun ONE Directory Server 5.1 instances to ensure availability of your data.
