System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Using Express Configuration
Use express configuration if you are installing Sun ONE Directory Server 5.1 to evaluate or test the product. Because express configuration does not offer you the choice of selecting your server port number or your directory suffix, you should not use it for production configurations. To perform an express configuration, do the following.
How to configure Sun ONE Directory Server 5.1 using express configuration
  1. Become superuser.
  2. Run the Sun ONE Directory Server 5.1 program by typing the following.
    # /usr/sbin/directoryserver setup
  3. When you are prompted for what you want to install, hit enter for [the default] Sun ONE servers.
  4. When you are prompted for the type of configuration, choose Express.
  5. For the user and group to run the servers as, enter the identity that you want this server to run as.
  6. For Configuration Directory Administrator ID and password, enter the name and password that you will log in as when you want to authenticate to the console with full privileges. Think of this as the root or superuser identity for the Sun ONE Console.
The server is then minimally configured, and started. You are told what host and port number on which the Administration Server is listening.
Note the following about your new Sun ONE Directory Server 5.1 configuration.
Do not modify the contents of the directory under the o=NetscapeRoot suffix. Either create data under the first suffix, or create a new suffix to be used for this purpose. For details on how to create new suffixes for your Sun ONE Directory Server 5.1, see the Sun ONE Directory Server 5.1 Administrator's Guide.
