The following lists the Solaris LDAP client's profile attributes, which can be set automatically when you run idsconfig(1M). See Initializing a Client Manually for information on how to set a client profile manually.
Table 13–2 Client Profile Attributes|
Attribute |
Description |
cn |
The profile name. No default value, must be specified. |
preferredServerList |
The host addresses of the preferred servers is a space separated list of server addresses. (Do not use host names.) The servers in this list are tried in order BEFORE those in the defaultServerList until a successful connection is made. This has no default value. At least one server must be specified in either preferredServerList or defaultServerList. |
defaultServerList |
The host addresses of the default servers is a space separated list of server addresses. (Do not use host names.) After the servers in the preferredServerlist are tried, those default servers on the client's subnet are tried, followed by the remaining default servers, until a connection is made. At least one server must be specified in either the preferredServerList or defaultServerList. The servers in this list are tried only after those on the preferred server list. This attribute has no default value. |
defaultSearchBase |
The DN relative to which to locate the well-known containers. There is no default for this value. However, this can be overridden for a given service by the serviceSearchDescriptor attribute. |
defaultSearchScope |
Defines the scope of a database search by a client. It can be overridden by the serviceSearchDescriptor attribute. The possible values are one or sub. The default value is a one level search. |
authenticationMethod |
Identifies the method of authentication used by the client. The default is none (anonymous). See Choosing Authentication Methods for more information. |
credentialLevel |
Identifies the type of credentials a client should use to authenticate. The choices are anonymous or proxy. The default is anonymous. |
serviceSearchDescriptor |
Defines how and where a client should search for a naming database, for example, if the client should look in one or more points in the DIT. By default no SSDs are defined. |
serviceAuthenticationMethod |
Authentication method used by a client for the specified service. By default, no service Authentication Methods are defined. If a service does not have serviceAuthenticationMethod defined, it will default to the value of authenticationMethod. |
attributeMap |
Attribute mappings used by client. By default no attributeMap is defined. |
objectclassMap |
Object class mappings used by client. By default no objectclassMap is defined. |
searchTimeLimit |
Maximum time [in seconds] a client should allow for a search to complete before timing out. This does not affect the time the LDAP server will allow for a search to complete. Default value is 30 seconds. |
bindTimeLimit |
Maximum time in seconds a client should allow to bind with a server before timing out. Default value is 30 seconds. |
followReferrals |
Specifies whether a client should follow an LDAP referral. Possible values TRUE or FALSE. The default value is TRUE. |
profileTTL |
Time between refreshes of the client profile from the LDAP server by the ldap_cachemgr(1M). Default is 43200 seconds or 12 hours. If given a value of 0, the profile will never be refreshed. |
The following table lists the client attributes that can be set locally usingldapclient(1M).
Table 13–3 Local Client Attributes|
Attribute |
Description |
domainName |
Specifies the client's domain name (which becomes the default domain for the client machine). This has no default value and must be specified. |
proxyDN |
The proxy's distinguished name. If the client machine is configured with credentialLevel of proxy, the proxyDN must be specified. |
proxyPassword |
The proxy's password. If the client machine is configured with credentialLevel of proxy, the proxyPassword must be defined. |
certificatePath |
The directory on the local file system containing the certificate databases. If a client machine is configured with authenticationMethod or serviceAuthenticationMethod using TLS, then this attribute is used. The default value is /var/ldap. |
If the BaseDN in an SSD contains a trailing comma, it is treated as a relative value of the defaultSearchBase. The values of the defaultSearchBase are appended to the BaseDN before a search is performed.
