TLS can be used to secure communication between an LDAP client and the directory server, providing both privacy and data integrity. The TLS protocol is a super set of the Secure Sockets Layer (SSL) protocol. Solaris LDAP naming services support TLS connections. Be aware that using SSL will add load to the directory server and the client.
You will need to set up your directory server for SSL. See the Sun ONE Directory Server 5.1 Administrator's Guide for more information on setting up Sun ONE Directory Server 5.1 for SSL. You will also need to set up your LDAP client for SSL.
In order to use TLS for Solaris LDAP naming services, the directory server must use the default ports, 389 and 636, for LDAP and SSL, respectively. If your directory server does not use these ports, you cannot use TLS at this time.
See Setting Up TLS Security for more information.
