ユーザーと役割に関する拡張属性のシステムごとの設定は、/etc/user_attr に置かれます。詳細については、user_attr(4) のマニュアルページを参照してください。
( 1.3.6.1.4.1.42.2.27.5.1.4 NAME 'SolarisAttrKeyValue' DESC 'Semi-colon separated key=value pairs of attributes' EQUALITY caseIgnoreIA5Match SUBSTRINGS caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.7 NAME 'SolarisAttrShortDesc' DESC 'Short description about an entry, used by GUIs' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.8 NAME 'SolarisAttrLongDesc' DESC 'Detail description about an entry' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.9 NAME 'SolarisKernelSecurityPolicy' DESC 'Solaris kernel security policy' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.10 NAME 'SolarisProfileType' DESC 'Type of object defined in profile' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.11 NAME 'SolarisProfileId' DESC 'Identifier of object defined in profile' EQUALITY caseExactIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.12 NAME 'SolarisUserQualifier' DESC 'Per-user login attributes' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.13 NAME 'SolarisReserved1' DESC 'Reserved for future use' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.14 NAME 'SolarisReserved2' DESC 'Reserved for future use' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) |
役割ベースのアクセス制御 objectClassses を次に示します。
( 1.3.6.1.4.1.42.2.27.5.2.3 NAME 'SolarisUserAttr' SUP top AUXILIARY
DESC 'User attributes'
MAY ( SolarisUserQualifier $ SolarisAttrReserved1 $ \
SolarisAttrReserved2 $ SolarisAttrKeyValue ) )
( 1.3.6.1.4.1.42.2.27.5.2.4 NAME 'SolarisAuthAttr' SUP top STRUCTURAL
DESC 'Authorizations data'
MUST cn
MAY ( SolarisAttrReserved1 $ SolarisAttrReserved2 $ \
SolarisAttrShortDesc $ SolarisAttrLongDesc $ \
( 1.3.6.1.4.1.42.2.27.5.2.5 NAME 'SolarisProfAttr' SUP top STRUCTURAL
DESC 'Profiles data'
MUST cn
SolarisAttrLongDesc $ SolarisAttrKeyValue ) )
( 1.3.6.1.4.1.42.2.27.5.2.6 NAME 'SolarisExecAttr' SUP top AUXILIARY
DESC 'Profiles execution attributes'
MAY ( SolarisKernelSecurityPolicy $ SolarisProfileType $ \
SolarisProfileId $ SolarisAttrKeyValue ) )
