metastat の出力はソートされていません。構成リストを編集したい場合は、metastat -p コマンドの出力を入力にして sort または grep コマンドを実行してください。
詳細は、metastat(1M) のマニュアルページを参照してください。
metastat コマンドの出力例を以下に示します。
# metastat
d50: RAID
State: Okay
Interlace: 32 blocks
Original device:
Device Start Block Dbase State Reloc Hot Spare
c1t4d0s5 330 No Okay Yes
c1t5d0s5 330 No Okay Yes
c2t4d0s5 330 No Okay Yes
c2t5d0s5 330 No Okay Yes
c1t1d0s5 330 No Okay Yes
c2t1d0s5 330 No Okay Yes
d1: Concat/Stripe
Stripe 0:
Device Start Block Dbase Reloc
c1t2d0s3 0 No Yes
d2: Concat/Stripe
Stripe 0:
c2t2d0s3 0 No Yes
d80: Soft Partition
Device: d70
State: Okay
Extent Start Block Block count
0 1 2097152
d81: Soft Partition
Device: d70
State: Okay
0 2097154 2097152
d70: Mirror
Submirror 0: d71
State: Okay
Submirror 1: d72
State: Okay
Pass: 1
Read option: roundrobin (default)
Write option: parallel (default)
d71: Submirror of d70
State: Okay
Stripe 0:
c1t3d0s3 0 No Okay Yes
Stripe 1:
c1t3d0s4 0 No Okay Yes
Stripe 2:
c1t3d0s5 0 No Okay Yes
d72: Submirror of d70
State: Okay
Stripe 0:
c2t3d0s3 0 No Okay Yes
Stripe 1:
c2t3d0s4 0 No Okay Yes
Stripe 2:
c2t3d0s5 0 No Okay Yes
hsp010: is empty
hsp014: 2 hot spares
Device Status Length Reloc
c1t2d0s1 Available 617652 blocks Yes
c2t2d0s1 Available 617652 blocks Yes
hsp050: 2 hot spares
c1t2d0s5 Available 4197879 blocks Yes
c2t2d0s5 Available 4197879 blocks Yes
hsp070: 2 hot spares
c1t2d0s4 Available 4197879 blocks Yes
c2t2d0s4 Available 4197879 blocks Yes
Device Relocation Information:
Device Reloc Device ID
c1t2d0 Yes id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N1S200002103AF29
c2t2d0 Yes id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0P64Z00002105Q6J7
c1t1d0 Yes id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N1EM00002104NP2J
c2t1d0 Yes id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N93J000071040L3S
c0t0d0 Yes id1,dad@s53554e575f4154415f5f53543339313430412525415933
