System Administration Guide: Resource Management and Network Services
Example—Editing Entries in an NIS+ mail_aliases Table
To edit entries in the table, follow these instructions.
  1. Either be a member of the NIS+ group that owns the table, or become root on the mail server, or assume an equivalent role.
    For information about roles, refer to “Using Privileged Applications” in System Administration Guide: Security Services.
  2. Display the alias entry.
    # aliasadm -m alias
    alias
    Use the assigned alias name.
  3. Edit the alias entry, as necessary.
    # aliasadm -c alias expanded_alias [options comments]
    alias
    If necessary, edit the alias name.
    expanded_alias
    If necessary, edit the expanded alias name.
    options
    If necessary, edit the option.
    comments
    If necessary, edit the comment for this entry.
    For more information, refer to the aliasadm(1M) man page, as well as Mail Alias Files.
  4. Display the entry that you have edited and ensure that the entry is correct.
    # aliasadm -m alias
For more information, refer to the aliasadm(1M) man page.
