System Administration Guide: Resource Management and Network Services
/etc/ppp/peers/myisp.tmpl Template File
The /etc/ppp/peers/myisp.tmpl file contains helpful comments about the /etc/ppp/peers/peer-name file. The template concludes with common options that you might use for an /etc/ppp/peers/peer-name file:
connect "/usr/bin/chat -f /etc/ppp/myisp-chat"
user myname
remotename myisp
noauth
noipdefault
defaultroute
updetach
noccp
Option
Definition
Call the peer by using the chat script /etc/ppp/myisp-chat.
user myname
Use this account name for the local machine. myname is the name for this machine in the peer's /etc/ppp/pap-secrets file.
remotename myisp
Recognize myisp as the name of the peer in the local machine's /etc/ppp/pap-secrets file.
noauth
Do not require calling peers to provide authentication credentials.
noipdefault
Do not use a default IP address for the local machine.
defaultroute
Use the default route that is assigned to the local machine.
updetach
Log errors in the PPP log files, rather than on the standard output.
noccp
Do not use CCP compression.
To use /etc/ppp/peers/myisp.tmpl at your site, rename /etc/ppp/peers/myisp.tmpl to /etc/ppp/peers/.peer-name. Replace peer-name with the name of the peer to be called. Then modify the file contents as needed by your site.
