System Administration Guide: Resource Management and Network Services
Assigning IP Addresses by sppp Unit Number
If you are using either PAP or CHAP authentication, you can assign IP addresses to callers by the sppp unit number. The next table shows an example of this usage.
Caller
Server
Password
IP Addresses
myclient
ISP-server
mypassword
10.10.111.240/28+
The plus sign (+) indicates that the unit number is added to the IP address. Addresses 10.10.111.240 through 10.10.111.255 are assigned to remote users. sppp0 gets IP address 10.10.111.240. sppp1 gets IP address 10.10.111.241, and so on.
