Task |
For Instructions |
Configure another dial-out machine |
How to Configure the Modem and Serial Port (Dial-out Machine). |
Test modem connectivity by dialing out to another computer |
cu(1C) and tip(1) man pages. These utilities can help you test if your modem is properly configured. Also, use these utitlities to test if you can establish a connection with another machine. |
Get detailed information about the PPP configuration files | |
Begin configuring the dial-in server |
