System Administration Guide: Resource Management and Network Services
Before You Set Up the Leased-Line Link
When your company rents a leased-line link from a network provider, you typically configure only the system at your end of the link. The peer at the other end of the link is maintained by another administrator. This individual might be a system administrator at a remote location in your company or a system administrator at an ISP.
Hardware That Is Needed for a Leased-Line Link
In addition to the link media, your end of the link requires the following hardware:
Some network providers include a router, synchronous interface, and a CSU/DSU as part of the customer premises equipment (CPE). However, necessary equipment varies, based on the provider and any governmental restrictions in your locale. The network provider can give you information about the unit that is needed, if this equipment is not provided with the leased line.
Information to Be Gathered for the Leased-Line Link
Before you configure the local peer, you might need to gather the items that are listed in the next table.
Table 30–4 Planning for a Leased-Line Link
Information
Action
Device name of the interface
Refer to the Interface card documentation.
Configuration instructions for the synchronous interface card
Refer to the Interface card documentation. You need this information to configure the HSI/S interface. You might not need to configure other types of interface cards.
(Optional) IP address of the remote peer
Refer to the service provider documentation. Alternatively, contact the system administrator of the remote peer. This information is needed only if the IP address is not negotiated between the two peers.
(Optional) Name of the remote peer
Refer to the service provider documentation. Alternatively, you can contact the system administrator of the remote peer.
(Optional) Speed of the link
(Optional) Compression that is used by the remote peer
