System Administration Guide: Resource Management and Network Services
Miscellaneous Error Messages
dir mountpoint must start with '/'
The automounter mount point must be given as a full path name. Check the spelling and path name of the mount point.
hierarchical mountpoints: pathname1 and pathname2
Autofs does not allow its mount points to have a hierarchical relationship. An autofs mount point must not be contained within another automounted file system.
host server not responding
Autofs attempted to contact server, but received no response.
hostname: exports: rpc_err
An error occurred while getting the export list from hostname. This message indicates a server or network problem.
map mapname, key key: bad
The map entry is malformed, and autofs cannot interpret the entry. Recheck the entry. Perhaps the entry has characters that need escaping.
mapname: nis_err
An error occurred when looking up an entry in a NIS map. This message can indicate NIS problems.
mount of server:pathname on mountpoint:reason
Autofs failed to do a mount. This occurrence can indicate a server or network problem.
mountpoint: Not a directory
Autofs cannot mount itself on mountpoint because it is not a directory. Check the spelling and path name of the mount point.
nfscast: cannot send packet: reason
Autofs cannot send a query packet to a server in a list of replicated file system locations.
nfscast: cannot receive reply: reason
Autofs cannot receive replies from any of the servers in a list of replicated file system locations.
nfscast: select: reason
All these error messages indicate problems in attempting to ping servers for a replicated file system. This message can indicate a network problem.
pathconf: no info for server:pathname
Autofs failed to get pathconf information for the path name (see the fpathconf(2) man page).
pathconf: server: server not responding
Autofs is unable to contact the mount daemon on server that provides the information to pathconf().
