System Administration Guide: Resource Management and Network Services
mountall
Use this command to mount all file systems or a specific group of file systems that are listed in a file-system table. The command provides a way to do the following:
Because all file systems that are labeled as NFS file-system type are remote file systems, some of these options are redundant. For more information, see the mountall(1M) man page.
Using the mountall Command
These two examples are equivalent:
# mountall -F nfs
# mountall -F nfs -r
