System Administration Guide: Resource Management and Network Services
Command Options Used With Projects and Tasks
ps
Use ps -o to display task and project IDs. For example, to view the project ID, type the following:
# ps -o user,pid,uid,projid
USER PID   UID  PROJID
jtd  89430 124  4113
id
Use id -p to print the current project ID in addition to the user and group IDs. If the user operand is provided, the project associated with that user's normal login is printed:
#  id -p
uid=124(jtd) gid=10(staff) projid=4113(booksite)
pgrep and pkill
To match only processes with a project ID in a specific list, type the following:
# pgrep -J projidlist
# pkill -J projidlist
To match only processes with a task ID in a specific list, type the following:
# pgrep -T taskidlist
# pkill -T taskidlist
prstat
To display various statistics for processes and projects that are currently running on your system, type the following:
% prstat -J
	  PID USERNAME  SIZE   RSS STATE  PRI NICE      TIME  CPU PROCESS/NLWP
 21634 jtd      5512K 4848K cpu0    44    0   0:00.00 0.3% prstat/1
   324 root       29M   75M sleep   59    0   0:08.27 0.2% Xsun/1
 15497 jtd        48M   41M sleep   49    0   0:08.26 0.1% adeptedit/1
   328 root     2856K 2600K sleep   58    0   0:00.00 0.0% mibiisa/11
  1979 jtd      1568K 1352K sleep   49    0   0:00.00 0.0% csh/1
  1977 jtd      7256K 5512K sleep   49    0   0:00.00 0.0% dtterm/1
   192 root     3680K 2856K sleep   58    0   0:00.36 0.0% automountd/5
  1845 jtd        24M   22M sleep   49    0   0:00.29 0.0% dtmail/11
  1009 jtd      9864K 8384K sleep   49    0   0:00.59 0.0% dtwm/8
   114 root     1640K  704K sleep   58    0   0:01.16 0.0% in.routed/1
   180 daemon   2704K 1944K sleep   58    0   0:00.00 0.0% statd/4
   145 root     2120K 1520K sleep   58    0   0:00.00 0.0% ypbind/1
   181 root     1864K 1336K sleep   51    0   0:00.00 0.0% lockd/1
   173 root     2584K 2136K sleep   58    0   0:00.00 0.0% inetd/1
   135 root     2960K 1424K sleep    0    0   0:00.00 0.0% keyserv/4
PROJID    NPROC  SIZE   RSS MEMORY      TIME  CPU PROJECT
    10       52  400M  271M    68%   0:11.45 0.4% booksite
     0       35  113M  129M    32%   0:10.46 0.2% system
Total: 87 processes, 205 lwps, load averages: 0.05, 0.02, 0.02
To display various statistics for processes and tasks that are currently running on your system, type the following:
% prstat -T
 23023 root       26M   20M sleep   59    0   0:03:18 0.6% Xsun/1
 23476 jtd        51M   45M sleep   49    0   0:04:31 0.5% adeptedit/1
 23432 jtd      6928K 5064K sleep   59    0   0:00:00 0.1% dtterm/1
 28959 jtd        26M   18M sleep   49    0   0:00:18 0.0% .netscape.bin/1
 23116 jtd      9232K 8104K sleep   59    0   0:00:27 0.0% dtwm/5
 29010 jtd      5144K 4664K cpu0    59    0   0:00:00 0.0% prstat/1
   200 root     3096K 1024K sleep   59    0   0:00:00 0.0% lpsched/1
   161 root     2120K 1600K sleep   59    0   0:00:00 0.0% lockd/2
   170 root     5888K 4248K sleep   59    0   0:03:10 0.0% automountd/3
   132 root     2120K 1408K sleep   59    0   0:00:00 0.0% ypbind/1
   162 daemon   2504K 1936K sleep   59    0   0:00:00 0.0% statd/2
   146 root     2560K 2008K sleep   59    0   0:00:00 0.0% inetd/1
   122 root     2336K 1264K sleep   59    0   0:00:00 0.0% keyserv/2
   119 root     2336K 1496K sleep   59    0   0:00:02 0.0% rpcbind/1
   104 root     1664K  672K sleep   59    0   0:00:03 0.0% in.rdisc/1
TASKID    NPROC  SIZE   RSS MEMORY      TIME  CPU PROJECT
   222       30  229M  161M    44%   0:05:54 0.6% group.staff
   223        1   26M   20M   5.3%   0:03:18 0.6% group.staff
    12        1   61M   33M   8.9%   0:00:31 0.0% group.staff
     1       33   85M   53M    14%   0:03:33 0.0% system
Total: 65 processes, 154 lwps, load averages: 0.04, 0.05, 0.06
Note –
The -J and -T options cannot be used together.
