System Administration Guide: Resource Management and Network Services
New Macros Used to Build the sendmail Configuration File
In this section, you can find the following.
Table 27–11 New Macros Used to Build the sendmail Configuration File
Macro
Description
LOCAL_MAILER_EOL
Overrides the default end-of-line string for the local mailer.
LOCAL_MAILER_FLAGS
Adds Return-Path: header by default.
MAIL_SETTINGS_DIR
Contains the path (including the trailing slash) for the mail settings directory.
MODIFY_MAILER_FLAGS
Improves the *_MAILER_FLAGS. This macro sets, adds, or deletes flags.
RELAY_MAILER_FLAGS
Defines additional flags for the relay mailer.
New MAX Macros
Use the following new macros to configure the maximum number of commands that can be received before sendmail slows its delivery. You can set these MAX macros at compile time. The maximum values in the following table also represent the current default values.
Table 27–12 New MAX Macros
Macro
Maximum Value
Commands Checked by Each Macro
MAXBADCOMMANDS
25
Unknown commands
MAXNOOPCOMMANDS
20
NOOP, VERB, ONEX, XUSR
MAXHELOCOMMANDS
3
HELO, EHLO
MAXVRFYCOMMANDS
6
VRFY, EXPN
MAXETRNCOMMANDS
8
ETRN
Note –
You can disable a macro's check by setting the macro's value to zero.
