System Administration Guide: Resource Management and Network Services
UUCP Type Field
This field contains the device type that should be used to establish the communication link to the remote computer. The keyword that is used in this field is matched against the first field of Devices file entries.
Example 40–2 Type Field and /etc/uucp/Devices File
File Name System-Name  Time  Type     Speed  Phone     Chat Script
Systems   arabian      Any   ACUEC, g 38400  1112222   ogin: Puucp ssword:beledi
You can define the protocol that is used to contact the system by adding it on to the Type field. The previous example shows how to attach the protocol g to the device type ACUEC. For information on protocols, see UUCP Protocol Definitions in the Devices File.
