The Dialer-Token-Pairs (DTP) field contains the name of a dialer and the token to pass it. The DTP field has this syntax:
dialer token [dialer token]
The dialer portion can be the name of a modem, a port monitor, or it can be direct or uudirect for a direct-link device. You can have any number of dialer-token pairs. If the dialer portion is not present, it is taken from a related entry in the Systems file. The token portion can be supplied immediately after the dialer portion.
The last dialer-token pair might not be present, depending on the associated dialer. In most situations, the last pair contains only a dialer portion. The token portion is retrieved from the Phone field of the associated Systems file entry.
A valid entry in the dialer portion can be defined in the Dialers file or can be one of several special dialer types. These special dialer types are compiled into the software and are therefore available without having entries in the Dialers file. The following table shows the special dialer types.
Table 40–3 Dialer-Token Pairs
TCP/IP network |
Transport Level Interface Network (without STREAMS) |
Transport Level Interface Network (with STREAMS) |
See UUCP Protocol Definitions in the Devices File for more information.
The DTP field can be structured four different ways, depending on the device that is associated with the entry:
Directly connected modem
If a modem is connected directly to a port on your computer, the DTP field of the associated Devices file entry has only one pair. This pair would normally be the name of the modem. This name is used to match the particular Devices file entry with an entry in the Dialers file. Therefore, the Dialer field must match the first field of a Dialers file entry.
Dialers hayes =,-, "" \\dA\pTE1V1X1Q0S2=255S12=255\r\c \EATDT\T\r\c CONNECT |
Notice that only the dialer portion (hayes) is present in the DTP field of the Devices file entry. This means that the token to be passed on to the dialer (in this instance, the phone number) is taken from the Phone field of a Systems file entry. (\T is implied, as described in Example 40–9.)
Direct link – For a direct link to a particular computer, the DTP field of the associated entry would contain the keyword direct. This is true for both types of direct-link entries, Direct and Sys-Name (refer to UUCP Type Field).
Computers on the same port selector – If a computer with which you intend to communicate is on the same port selector switch as your computer, your computer must first access the switch. The switch then makes the connection to the other computer. This type of entry has only one pair. The dialer portion is used to match a Dialers file entry.
Dialers develcon ,"" "" \pr\ps\c est:\007 \E\D\e \007 |
As shown, the token portion is left blank. This designation indicates that it is retrieved from the Systems file. The Systems file entry for this computer contains the token in the Phone field, which is normally reserved for the phone number of the computer. Refer to UUCP /etc/uucp/Systems File for details. This type of DTP contains an escape character (\D), which ensures that the contents of the Phone field are not interpreted as a valid entry in the Dialcodes file.
Modems that are connected to port selector – If a high-speed modem is connected to a port selector, your computer must first access the port selector switch. The switch makes the connection to the modem. This type of entry requires two dialer-token-pairs. The dialer portion of each pair (fifth and seventh fields of entry) is used to match entries in the Dialers file, as shown below.
Dialers develcon "" "" \pr\ps\c est:\007 \E\D\e \007 Dialers ventel =&-% t"" \r\p\r\c $ <K\T%\r>\c ONLINE! |
In the first pair, develcon is the dialer and vent is the token that is passed to the Develcon switch to tell it which device (such as Ventel modem) to connect to your computer. This token is unique for each port selector, as each switch can be set up differently. After the Ventel modem has been connected, the second pair is accessed. Ventel is the dialer and the token is retrieved from the Systems file.
Two escape characters can appear in a DTP field:
\T – Indicates that the Phone (token) field should be translated by using the /etc/uucp/Dialcodes file. This escape character is normally placed in the /etc/uucp/Dialers file for each caller script that is associated with a modem (Hayes, US Robotics, and so on). Therefore, the translation does not occur until the caller script is accessed.
\D – Indicates that the Phone (token) field should not be translated by using the /etc/uucp/Dialcodes file. If no escape character is specified at the end of a Devices entry, the \D is assumed (default). A \D is also used in the /etc/uucp/Dialers file with entries that are associated with network switches (develcon and micom).
