System Administration Guide: Resource Management and Network Services
UUCP NOREAD and NOWRITE Options
The NOREAD and NOWRITE options specify exceptions to the READ and WRITE options or defaults. The following entry permits reading any file except those files in the /etc directory (and its subdirectories—remember, these options are prefixes).
READ=/ NOREAD=/etc WRITE=/var/spool/uucppublic
This entry permits writing only to the default /var/spool/uucppublic directory. NOWRITE works in the same manner as the NOREAD option. You can use the NOREAD and NOWRITE options in both LOGNAME and MACHINE entries.
