System Administration Guide: Resource Management and Network Services
UUCP Job-size Field
This field specifies the maximum job size that can be entered in the queue. Job-size is measured in bytes and can be a list of the options that are listed in the following table.
Table 40–8 Job-size Field
nnnn
Integer that specifies the maximum job size for this job grade
nK
Decimal number that represents the number of kilobytes (K is an abbreviation for kilobyte)
nM
Decimal number that represents the number of megabytes (M is an abbreviation for megabyte)
Any
Keyword that specifies that no maximum job size exists
Here are some examples:
