The exit token records the exit status of a program. The exit token contains the following fields:
A token ID that identifies this token as an exit token
A program exit status as passed to the exit() system call
A return value that describes the exit status or that provides a system error number
The praudit command displays the exit token as follows:
exit,Error 0,0 |
The following figure shows the format of an exit token.
