This token has been replaced by the newgroups token, which provides the same type of information but requires less space. A description of the group token is provided here for completeness, but the application designer should use the newgroups token. Notice that praudit does not distinguish between the two tokens, as both token IDs are labeled group in praudit output.
The group token records the groups entries from the process's credential. The group token has two fixed fields:
A token ID that identifies this token as a group token
An array of group entries of size NGROUPS_MAX (16)
The remainder of the token consists of zero or more group entries. The praudit command displays the group token as follows:
group,staff,admin,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1 |
The following figure shows the format of a group token.
The group token is output only when the audit policy group is active.
