The in_addr token contains an Internet Protocol address. Since the Solaris 8 release, the Internet address can be displayed in IPv4 format or IPv6 format. The IPv4 address uses 4 bytes. The IPv6 address uses 16 bytes to describe the type, and 16 bytes to describe the address. The in_addr token has two fields:
A token ID that identifies this token as an in_addr token
An Internet address
The praudit command displays the in_addr token as follows:
ip address,129.150.113.7 |
The following figure shows the format of an in_addr token.
