System Administration Guide: Security Services
newgroups Token
This token replaces the group token. Notice that the praudit command does not distinguish between the two tokens, as both token IDs are labeled group in praudit output.
The newgroups token records the group entries from the process's credential. The newgroups token has two fixed fields:
The remainder of this token is composed of zero or more group entries. The praudit command displays the newgroups token as follows:
group, staff, admin
The following figure shows the format of a newgroups token.
Figure 23–19 newgroups Token Format
The preceding context describes the graphic.
Note –
The newgroups token is output only when the group audit policy is active.
