System Administration Guide: Security Services
arg Token
The arg token contains information about the arguments to a system call: the argument number of the system call, the argument value, and an optional description. This token allows a 32-bit integer system-call argument in an audit record. The arg token has five fields:
The praudit command displays the arg token as follows:
argument,1,0x00000000,addr
The following figure shows the format of the arg token.
Figure 23–6 arg Token Format
The preceding context describes the graphic.
