This chapter describes the important components of the BSM service, which are the auditing subsystem and the device allocation mechanism.
The auditing mechanism helps you detect potential security breaches by revealing suspicious or abnormal patterns of system usage. The auditing mechanism also provides a means to trace suspect actions back to a particular user, thus serving as a deterrent. If users know that their activities are likely to be audited, they might be less likely to attempt malicious activities.
The following is a list of the reference information in this chapter.
For an overview of auditing, see Chapter 20, BSM (Overview). For planning suggestions, see Chapter 21, Audit Planning. For procedures to configure auditing at your site, see Chapter 22, Managing the BSM Service (Tasks).
This section provides information about the commands that are used with the auditing service.
The following list summarizes what the audit daemon, auditd, does.
auditd opens and closes audit log files in the directories that are specified in the audit_control file, in the order in which they are specified.
auditd reads audit data from the kernel and writes the data to an audit log file.
auditd executes the audit_warn script when the audit directories fill past limits that are specified in the audit_control file. The script, by default, sends warnings to the audit_warn mail alias and to the console.
By default, when all audit directories are full, processes that generate audit records are suspended. In addition, the auditd command writes a message to the console and to the audit_warn mail alias. The audit policy can be reconfigured with the auditconfig command. At this point, only the system administrator fix the auditing mechanism. The administrator can log in to write audit files to tape, can delete audit files from the system, and can do other cleanup.
The auditd daemon can be started automatically when the machine is brought up to multiuser mode, or you can start it from the command line. When the audit daemon is started, it determines the amount of free space necessary for audit log files.
The daemon uses the list of audit directories in the audit_control file as possible locations for creating audit files. The audit daemon maintains a pointer into this list of directories, starting with the first directory. Every time the audit daemon needs to create an audit file, it puts the file into the first available directory in the list. The list starts at the audit daemon's current pointer. You can reset the pointer to the beginning of the list by running the audit -s command. The audit -n command instructs the daemon to switch to a new audit file. The new file is created in the same directory as the current file.
The audit command controls the actions of the audit daemon. The audit command can do the following tasks:
Enable and disable auditing
Reset the audit daemon
Adjust the auditing preselection mask on the local machine
Write audit records to a different audit log file
See the audit(1M) man page for a discussion of the available options.
The bsmrecord command displays the format of audit events that are defined in the /etc/security/audit_event file. The output includes the event's audit ID, audit class, audit flag, and the record's tokens in order. With no option, the bsmrecord output displays well in a terminal window. With the -h option, the output is suitable for viewing in a browser. See How to Display Audit Record Formats for examples of its use. For more information, see the bsmrecord(1M) man page.
Use the auditreduce command to merge audit records from one or more input audit files. The command can also be used to perform a post selection of audit records. See the auditreduce(1M) man page. To merge the entire audit trail, run this command on the audit server. The audit server is the machine that mounts all the audit file systems for the installation.
The auditreduce command enables you to track all auditable actions on multiple machines from a single location. The command can read the logical combination of all audit files as a single audit trail. You must identically configure all machines at a site for auditing, and create servers and local directories for the audit log files. The auditreduce command ignores how the records were generated or where they are stored. Without options, the auditreduce command merges audit records from all the audit files in all of the subdirectories in the audit root directory. Typically, /etc/security/audit is the audit root directory. The auditreduce command sends the merge result to standard output. You can also place the result into a single, chronologically ordered output file. The file contains binary data.
The auditreduce command also can select particular types of records for analysis. The merging functions and selecting functions of the auditreduce command are logically independent. auditreduce captures data from the input files as the records are read, before the files are merged and then written to disk.
The praudit command makes the binary output of the auditreduce command readable.
By specifying options to the auditreduce command, you can also do the following:
Request audit records that were generated by only certain audit flags
Request audit records that were generated by one particular user
Request audit records that were generated on specific dates
With no arguments, auditreduce checks the subdirectories within the /etc/security/audit directory, the default audit root directory. The command checks for a files directory in which the start-time.end-time.hostname files reside. The auditreduce command is very useful when audit data resides in separate directories. Figure 23–1 illustrates audit data in separate directories for different hosts. Figure 23–2) illustrates audit data in separate directories for different audit servers.
If the partition for /etc/security/audit is very small, you might not store audit data in the default directory. You can pass the auditreduce command another directory by using the -R option:
# auditreduce -R /var/audit-alt |
You can also specify a particular subdirectory by using the -S option:
# auditreduce -S /var/audit-alt/host1 |
You can direct auditreduce to process only certain audit log files by specifying them as command arguments:
# auditreduce /var/audit/egret/files/2001*.2001*egret |
For other options and additional examples, see the auditreduce(1M) man page.
The praudit command reads audit records in binary format from standard input and displays the records in a presentable format. The input can be piped from the auditreduce command or from a single audit file. Input can also be produced with the cat command to concatenate several files, or the tail command for a current audit file.
The praudit command can generate five output formats:
Default – The default option displays one audit token per line. The default option displays the audit event by its description, such as ioctl(2), and displays any value that could be text in text format. For example, a user is displayed as the user name, not as the user ID.
–l option – The long option displays one audit record per line. The -d option changes the delimiter used between token fields, and between tokens. The default delimiter is a comma.
–r option – The raw option displays as a number any value that could be numeric. For example, a user is displayed by user ID, Internet addresses are in hexadecimal format, and modes are in octal format. The audit event is displayed as its event number, such as 158.
–s option – The short option displays the audit event by its table name, for example, AUE_IOCTL. The option displays the other tokens as the default option displays them.
–x option – The XML option displays the audit record in XML format. This option is useful as input to browsers, or as input to scripts that manipulate XML.
The XML is described by a DTD that the audit subsystem provides. Solaris software also provides a style sheet. The DTD and the style sheet are in the /usr/share/lib/xml directory.
In the default output format of praudit, each record is easily identified as a sequence of audit tokens. Each token is on a separate line. Each record begins with a header token. You could, for example, further process the output with the awk command.
Here is the default output from the praudit command for a header token:
header,240,1,ioctl(2),es,Tue Sept 7 16:11:44 1999, + 270 msec |
Here is the output from the praudit -r command for the same header token:
20,240,1,158,0003,699754304, + 270 msec |
Sometimes, you might want to manipulate output from the praudit command as lines of text. For example, you might want to select records that the auditreduce command cannot select. You can use a simple shell script to process the output of praudit. The following simple example script puts one audit record on one line, searches for a user-specified string, then returns the audit file to its original form. Specifically, the script does the following:
Marks the header tokens by prefixing them with Control-A
Combines all the audit tokens for one record onto one line while preserving the line breaks as Control-A
Runs the grep command
Restores the original newline breaks
#!/bin/sh praudit | sed -e '1,2d' -e '$s/^file.*$//' -e 's/^header/^aheader/' \\ | tr '\\012\\001' '\\002\\012' \\ | grep "$1" \\ | tr '\\002' '\\012' |
Note that the ^a in the script is Control-A, not the two characters ^ and a. The prefix distinguishes the header token from the string header that might appear as text.
The auditconfig command provides a command-line interface to retrieve and set audit configuration parameters. The auditconfig command can do the following tasks:
Display, check, and configure audit policy
Determine if auditing is turned on or turned off
Turn auditing off and turn auditing on
Manage the audit directory and the audit file
Manage the audit queue
Get and set preselection masks
Get and set audit event to audit class mappings
Get and set configuration information, such as session ID and audit ID
Configure audit characteristics for a process, a shell, and a session
Reset audit statistics
See the auditconfig(1M) man page for a discussion of the command options.
Auditing uses the following files:
The /etc/system file contains commands that the kernel reads during initialization to customize the system operations. The bsmconv and bsmunconv shell scripts, which are used to activate and deactivate auditing, modify the /etc/system file. The bsmconv shell script adds the following line to the /etc/system file:
set c2audit:audit_load=1 |
The set c2audit:audit_load=1 command causes the auditing module, a kernel module, to be loaded when the system is booted. The bsmunconv shell script disables auditing when the system is rebooted. The command removes the c2audit line from the /etc/system file.
The /etc/security/audit_class file contains definitions of the existing audit classes. Audit classes are groups of audit events. Each class has an associated audit flag, which is the short name that stands for the class. You use the short name in the audit_control file to preselect the classes whose events you want to audit. The flags accept prefixes for finer–grained selection. See Audit Flag Syntax for more information.
The root user, or an administrator in an equivalent role, can modify the definitions of audit classes. This administrator can define new audit classes, rename existing classes, or otherwise change existing classes by editing the audit_class file in a text editor. See the audit_class(4) man page for more information. For descriptions of the audit flags, see Definitions of Audit Flags.
An /etc/security/audit_control file on each machine is read by the audit daemon. See the audit_control(4) man page. The audit_control file is located in the /etc/security directory. Each machine has its own local audit_control file. The file enables every machine to mount their audit file systems from different locations or in a different order. For example, the primary audit file system for machineA might be the secondary audit file system for machineB.
You specify four kinds of information in the audit_control file. Each line of information begins with a keyword.
The audit flags line begins with flags:. The line contains the audit flags that preselect which classes of events are audited for all users on the machine. The audit flags specified here are referred to as the machine-wide audit flags or the machine-wide audit preselection mask. Audit flags are separated by commas, with no spaces.
The nonattributable flags line begins with naflags:. The line contains the audit flags that preselect which classes of events are audited when an action cannot be attributed to a specific user. The flags are separated by commas, with no spaces.
The audit threshold line begins with minfree:. The line defines the minimum free-space level for all audit file systems. The minfree percentage must be greater than or equal to 0. The default is 20 percent. When an audit file system is 80 percent filled, the audit data is then stored in the next available audit directory. See the audit_warn(1M) man page.
The directory definition lines begin with dir:. Each line defines an audit file system and directory that the machine uses to store its audit log files. You can define one or more directory definition lines. The order of the dir: lines is significant. The auditd daemon creates audit files in the directories in the specified order. The first directory is the primary audit directory for the machine. The second directory is the secondary audit directory where the audit daemon creates audit trail files when the first directory becomes full, and so forth. See the audit(1M) man page.
An audit_control file is created during the configuration process on each machine.
When you make changes to the audit_control file, you then run the audit -s command to instruct the audit daemon to reread the file.
The audit -s command does not change the preselection mask for existing processes. Use auditconfig, setaudit, or auditon for existing processes. See the getaudit(2) and auditconfig(1M) man pages for more information.
The following is a sample audit_control file for the machine dopey. dopey uses two audit file systems on the audit server blinken, and a third audit file system that is mounted from the second audit server winken. The third file system is used only when the audit file systems on blinken become full or unavailable. The minfree value of 20 percent specifies that the warning script is run when the file systems are 80 percent filled. The flags specify that logins and administrative operations are to be audited. The operations are audited for success and for failure. Failures of all types, except failures to create a file system object, are to be audited. Non-attributable events are also audited.
flags:lo,am,-all,^-fc naflags:lo,nt minfree:20 dir:/etc/security/audit/blinken/files dir:/etc/security/audit/blinken.1/files # # Audit filesystem used when blinken fills up # dir:/etc/security/audit/winken |
When the auditd daemon starts on each machine, it creates the file /etc/security/audit_data. The format of the file consists of a single entry with the two fields separated by a colon. See the audit_data(4) man page. The first field is the audit daemon's process ID. The second field is the path name of the audit file to which the audit daemon is currently writing audit records. Here is an example:
# cat /etc/security/audit_data 116:/etc/security/audit/blinken.1/files/19990320100002.not_terminated.dopey |
The /etc/security/audit_event file contains the default event-to-class mappings.You can edit this file to change the class mappings. However, if you do so, you must reboot the system or run auditconfig -conf to read the changed mappings into the kernel. See the audit_event(4) man page.
The /etc/security/audit_startup script automatically starts the audit daemon when the system enters multiuser mode. The script is invoked as part of the startup sequence, just prior to the execution of the audit daemon. See the audit_startup(1M) man page for more information.
A default audit_startup script that automatically configures the event-to-class mappings and sets the audit policies. The script is created during the BSM package installation.
To audit some users differently from others, you can edit the /etc/security/audit_user file to add audit flags for individual users. If specified, these flags are combined with the system-wide flags in the audit_control file to determine which classes of events to audit for that user. The flags that you add to the user's entry in the audit_user file modify the defaults from the audit_control file in two ways:
By specifying event classes that are always to be audited for this user
By specifying event classes that are never to be audited for this user
Each user entry in the audit_user file contains three fields.
The username field
The always-audit field
The never-audit field
The audit fields are processed in sequence. The always-audit field turns on the auditing of the classes in that field. The never-audit field turns off the auditing of the classes in that field.
Avoid the common mistake of leaving the all audit flag in the never-audit field. This mistake causes all auditing to be turned off for that user, which overrides the flags that are set in the always-audit field. The flag also overrides machine-wide audit flags set in the audit_control file.
The never-audit flags for a user override the system defaults. You might not want to overrride system defaults. For example, suppose you want to audit everything for user tamiko for except for successful reads of file system objects. This strategy audits almost everything for a user. However, the strategy generates about three-quarters of the audit data that would be produced if all data reads were audited. You also want to apply the system defaults to tamiko. Here are two possible audit_user entries:
The correct entry:
tamiko:all,^+fr: |
The incorrect entry:
tamiko:all:+fr |
The first example means, “always audit everything except for successful file-reads.” The second example means, “always audit everything, but never audit successful file-reads.” The second example is incorrect because the never-audit field would override the system defaults. The first example achieves the desired effect: the always-audit flags include the exception to the all flag. Since no flag is in the never-audit field, the system defaults from the audit_control file are not overridden here.
Successful events and failed events are treated separately. A process could generate more audit records when an error occurs than when an event is successful.
Whenever the audit daemon encounters an unusual condition while writing audit records, it invokes the /etc/security/audit_warn script. See the audit_warn(1M) man page. You can customize this script for your site to warn of conditions that might require manual intervention. Or, you could specify how to handle those conditions automatically. For all error conditions, audit_warn writes a message to the console. audit_warn also sends a message to the audit_warn mail alias. You should set up this alias when you enable auditing.
When audit daemon detects the following conditions, it invokes the audit_warn script.
An audit directory has become more full than the minfree value allows. The minfree value or soft limit is a percentage of the space available on an audit file system.
The audit_warn script is invoked with the string soft and the name of the directory whose available space has gone below the minimum value. The audit daemon switches automatically to the next suitable directory. The daemon writes the audit files in this new directory until the directory reaches its minfree limit. The audit daemon then goes to each remaining directory in the order that is listed in the audit_control file. The daemon writes audit records until each directory is at its minfree limit.
All the audit directories have reached the minfree threshold.
The audit_warn script is invoked with the string allsoft. A message is written to the console. Mail is also sent to the audit_warn alias.
When all audit directories that are listed in the audit_control file have reached their minfree threshold, the audit daemon switches back to the first directory. The daemon writes audit records until the directory becomes completely full.
An audit directory has become completely full with no space remaining.
The audit_warn script is invoked with the string hard and the name of the directory. A message is written to the console. Mail is also sent to the audit_warn alias.
The audit daemon switches automatically to the next suitable directory with any space available. The audit daemon goes to each remaining directory in the order that is listed in the audit_control file. The daemon writes audit records until each directory is full.
All the audit directories are completely full. The audit_warn script is invoked with the string allhard as an argument.
In the default configuration, a message is written to the console. Mail is also sent to the audit_warn alias. The processes that generate audit records are suspended. The audit daemon goes into a loop, waiting for space to become available, and resumes processing audit records when that happens. While audit records are not being processed, no auditable activities occur. Every process that attempts to generate an audit record is suspended. For this reason, you should set up a separate audit administration account that could operate without any auditing enabled. Then, you could continue operations without being suspended.
An internal error occurs. Possible internal errors include the following:
ebusy – Another audit daemon process is already running
tmpfile – A temporary file cannot be used
auditsvc – The auditsvc() system call fails
postsigterm – A signal was received during auditing shutdown
Mail is sent to the audit_warn alias.
A problem is discovered with the syntax of the audit_control file. By default, a message is sent to the console. Mail is also sent to the audit_warn alias.
The Solaris operating environment provides profiles for configuring the audit service and for analyzing the audit trail.
Audit Control – Profile that enables a role to configure Solaris auditing. The profile grants authorizations to configure auditing files and to run auditing commands. Roles with the Audit Control profile can run the following commands: audit, auditd, auditconfig, bsmconv, and bsmunconv.
Audit Review – Profile that enables a role to analyze Solaris auditing records. The profile grants authorization to read audit records with the praudit and auditreduce commands. The role can also run the auditstat command.
System Administrator – Profile that includes the Audit Review profile. A role with the System Administrator profile can analyze audit records.
To assign a profile to a role, see Creating Roles.
Audit flags indicate classes of events to audit. Machine-wide defaults for auditing are specified for all users on each machine by flags in the audit_control file. The file is described in The audit_control File.
You can modify what is audited for individual users by putting audit flags in a user's entry in the audit_user file. The audit flags are also used as arguments to the auditconfig command. See the auditconfig(1M) man page.
The following table shows each predefined audit class. The table shows the audit flag, the long name, and a short description. The audit flag is the short name that stands for the class. You use these audit flags in the auditing configuration files to specify which classes of events to audit. You also use them as arguments to auditing commands, such as auditconfig. You can define new classes by modifying the audit_class file. You can also rename existing classes. See the audit_class(4) man page for more information.
Table 23–1 Predefined Audit Flags|
Short Name |
Long Name |
Short Description |
All classes (meta-class) |
Nonattributable events |
Read of data, open for reading |
Write of data, open for writing |
Access of object attributes: stat, pathconf |
Change of object attributes: chown, flock |
Creation of object |
Deletion of object |
Application-defined event |
Administrative actions (old administrative meta-class) |
Administrative actions (meta-class) |
Change system state |
System-wide administration |
User administration |
Audit utilization |
Process start and process stop |
Process modify |
Process (meta-class) |
Program execution |
Login and logout events |
Network events: bind, connect, accept |
Miscellaneous |
The prefixes to the audit flags determine whether a class of events is audited for success, or for failure. Without a prefix, a class is audited for success and for failure. The following table shows the format of the audit flag and some possible representations.
Table 23–2 Plus and Minus Prefixes to Audit Flags|
prefixflag |
Explanation |
lo |
Audit all successful attempts to log in and log out, and all failed attempts to log in. You cannot fail an attempt to log out. |
+lo |
Audit all successful attempts to log in and log out. |
-all |
Audit all failed events. |
+all |
Audit all successful events. |
The all flag can generate large amounts of data and fill up audit file systems quickly. Use the all flag only if you have extraordinary reasons to audit all activities.
Audit flags that were previously selected can be further modified by a caret prefix, ^. The following table shows how the caret prefix modifies a preselected audit flag.
Table 23–3 Caret Prefix That Modifies Already-Specified Audit Flags
The prefixes to the audit flags can be used in the following files and commands:
In the flags line in the audit_control file
In flags field in the user's entry in the audit_user file
With arguments to the auditconfig command
See The audit_control File for an example of using the prefixes in the audit_control file.
Audit policies determine if additional information is added to the audit trail. The audit policies are described in Determining Which Audit Policies to Use.
The following audit characteristics are set at initial login:
Process preselection mask – A combination of the audit flags from the audit_control file and the audit_user file. When a user logs in, the login command combines the flags to establish the process preselection mask for the user's processes. The process preselection mask specifies whether events in each audit event class are to generate audit records.
The algorithm for obtaining the process preselection mask is described in the following equation:
user's process preselection mask = (flags: line + always-audit flags) - never-audit flags |
Add the audit flags from the flags: line in the audit_control file to the flags from the always-audit field in the user's entry in the audit_user file. Then, subtract from the total the flags from the user's never-audit field.
Audit ID – A process acquires an audit ID when the user logs in. The audit ID is inherited by all child processes that were started by the user's initial process. The audit ID helps enforce accountability. Even after a user becomes root, the audit ID remains the same. The audit ID that is saved in each audit record always allows you to trace actions back to the original user who had logged in.
Audit Session ID – The audit session ID is assigned at login. The session ID is inherited by all descendant processes.
Terminal ID (port ID, machine ID) – The terminal ID consists of the host name and the Internet address, followed by a unique number that identifies the physical device on which the user logged in. Most often, the login is through the console and the number that corresponds to the console device is 0.
The audit trail is created by the audit daemon. The audit daemon starts on each machine when the machine is brought up. After the auditd daemon starts at boot time, it is responsible for collecting the audit trail data and writing the audit records into audit files, which are also called audit log files. For a description of the file format, see the audit.log(4) man page. See also the auditd(1M) man page.
Even though you can physically locate audit directories within file systems that are not dedicated to auditing, do not do so except for directories of last resort. Directories of last resort are directories where audit files are written only when there is no other suitable directory available.
There is one other scenario where locating audit directories outside of dedicated audit file systems could be acceptable. You might do so in a software development environment where auditing is optional. To make full use of disk space might be more important than to keep an audit trail. However, in a security-conscious environment, audit directories within other file systems is not acceptable.
You should also consider the following factors.
A host should have at least one local audit directory. The local directory can be used as a directory of last resort if the host is unable to communicate with the audit server.
Mount audit directories with the read-write (rw) option. When you mount audit directories remotely, also use the intr and noac options.
List the audit file systems on the audit server where they reside. The export list should include all machines in the configuration.
Each audit file is a self-contained collection of records. The file's name identifies the time span during which the records were generated and the machine that generated them.
Audit files that are complete have names of the following form:
start-time.finish-time.machine |
where
start-time – Is the time that the first audit record in the audit file was generated.
finish-time – Is the time that the last record was written to the file.
machine – Is the name of the machine that generated the file.
For an example of these names, see Example of a Closed Audit File Name.
An audit log file that is still active has a name of the following form:
start-time.not_terminated.machine |
The time stamps in file names are used by the auditreduce command to locate records within a specific time range. These time stamps are important because there can be a month's accumulation or more of audit files online. To search all the files for records that were generated in the last 24 hours would be unacceptably expensive.
The start-time and end-time are timestamps with one-second resolution. They are specified in Greenwich Mean Time (GMT). The format is four digits for the year, followed by two digits for each month, day, hour, minute, and second, as follows:
YYYYMMDDHHMMSS |
The timestamps are in GMT to ensure that they sort in proper order even across a daylight savings time boundary. Because they are in GMT, the date and hour must be translated to the current time zone to be meaningful. Beware of this point whenever you manipulate these files with standard file commands rather than with the auditreduce command.
The format of a file name of a still-active file is as follows:
YYYYMMDDHHMMSS.not_terminated.machine |
Here is an example:
19990327225243.not_terminated.dopey |
The audit log files are named by the beginning date. So, in the example above the audit file was created in 1999, on March 27, at 10:52:43 p.m, GMT. The not_terminated in the file name means either that the file is still active or that the auditd daemon was unexpectedly interrupted. The name dopey at the end is the host name of the machine whose audit data is being collected.
The format of the name of a closed audit log file is as follows:
YYYYMMDDHHMMSS.YYYYMMDDHHMMSS.hostname |
Here is an example:
19990320005243.19900327225351.dopey |
In this example, the audit log file was created in 1999, on March 20, at 12:52:43 a.m., GMT. The file was closed March 27, at 10:53:51 p.m., GMT. The name dopey at the end is the host name of the machine whose audit data was collected.
Whenever auditd is unexpectedly interrupted, the audit file that is open at the time retains the not_terminated file name designation. For example, when a machine is writing to a remotely mounted audit file, the file server can become inaccessible. When the mounted audit file cannot be reached, the not_terminated designation remains in the file's name. When service is restored, the audit daemon opens a new audit file and keeps the old audit file name intact.
An audit record is a sequence of audit tokens. Each audit token contains event information such as user ID, time, and date. A header token begins an audit record, and an optional trailer token concludes the record. Other audit tokens contain information relevant to the auditable event. The following figure shows a typical audit record.
Each token has a token type identifier followed by data that is specific to the token. Each token type has its own format. The following table shows the token names with a description of each token.
Table 23–4 Audit Tokens for the Basic Security Module|
Token Name |
Description |
For More Information |
acl |
Access Control List information | |
arbitrary |
Data with format and type information | |
arg |
System call argument value | |
attr |
file vnode tokens | |
exec_args |
Exec system call arguments | |
exec_env |
Exec system call environment variables | |
exit |
Program exit information | |
file |
Audit file information | |
groups |
Process groups information | |
header |
Indicates start of audit record | |
in_addr |
Internet address | |
ip |
IP header information | |
ipc |
System V IPC information | |
ipc_perm |
System V IPC object tokens | |
iport |
Internet port address | |
newgroups |
opaque |
Unstructured data (unspecified format) | |
path |
Path information | |
process |
Process token information | |
return |
Status of system call | |
seq |
Sequence number token | |
socket |
Socket type and addresses | |
subject |
Subject token information (same format as process token) | |
text |
ASCII string | |
trailer |
Indicates end of audit record |
An audit record always contains a header token. The header token indicates where the audit record begins in the audit trail. Every audit record contains a subject token, except for audit records from some nonattributable events. In the case of attributable events, these two tokens refer to the values of the process that caused the event. In the case of asynchronous events, the process tokens refer to the system.
The acl token records information about Access Control Lists. This token consists of four fixed fields:
A token ID that identifies this token as an acl token
A field that specifies the ACL type
An ACL ID field
A field that lists the permissions associated with this ACL
The praudit command displays the acl token as follows:
acl,tpanero,staff,0755 |
The following figure shows the format of the acl token.
The arbitrary token encapsulates data for the audit trail. This token consists of four fixed fields and an array of data. The fixed fields are as follows:
A token ID that identifies this token as an arbitrary token
A suggested format field, such as hexadecimal
A size field that specifies the size of the data that is encapsulated, such as short
A count field that provides the number of following items
The remainder of the token is composed of one or more items of the specified type. The praudit command displays the arbitrary token as follows:
arbitrary,decimal,int,1 42 |
The following figure shows the format of the arbitrary token.
The following table shows the possible values of the print format field. Table 23–5.
Table 23–5 Values for the arbitrary Token's Print Format Field|
Value |
Action |
AUP_BINARY |
Prints the date in binary format |
AUP_OCTAL |
Prints the date in octal format |
AUP_DECIMAL |
Prints the date in decimal format |
AUP_HEX |
Prints the date in hexadecimal format |
AUP_STRING |
Prints the date as a string |
The following table shows the possible values of the item size field.
Table 23–6 Values for the arbitrary Token's Item Size Field|
Value |
Action |
AUR_BYTE |
Data is printed in units of bytes in 1 byte |
AUR_SHORT |
Data is printed in units of shorts in 2 bytes |
AUR_LONG |
Data is printed in units of longs in 4 bytes |
The arg token contains information about the arguments to a system call: the argument number of the system call, the argument value, and an optional description. This token allows a 32-bit integer system-call argument in an audit record. The arg token has five fields:
A token ID that identifies this token as an arg token
An argument ID that tells which system call argument that the token refers to
The argument value
The length of the descriptive text string
The text string
The praudit command displays the arg token as follows:
argument,1,0x00000000,addr |
The following figure shows the format of the arg token.
The attr token contains information from the file vnode. This token has seven fields:
A token ID that identifies this token as an attr token
The file access mode and type
The owner user ID
The owner group ID
The file system ID
The inode ID
The device ID the file might represent
See the statvfs(2) man page for further information about the file system ID and the device ID.
The attr token usually accompanies a path token. The attr token is produced during path searches. In the event of a path-search error, there is no vnode available to obtain the necessary file information. Therefore, the attr token is not included as part of the audit record. The praudit command displays the attr token as follows:
attribute,100555,root,staff,1805,13871,-4288 |
The following figure shows the format of an attr token.
The exec_args token records the arguments to an exec() system call. The exec_args token has two fixed fields:
A token ID field that identifies this token as an exec_args token
A count that represents the number of arguments that are passed to the exec() system call
The remainder of this token is composed of zero or more null-terminated strings. The praudit command displays the exec_args token as follows:
vi,/etc/security/audit_user |
The following figure shows the format of an exec_args token.
The exec_args token is output only when the audit policy argv is active.
The exec_env token records the current environment variables to an exec() system call. The exec_env token has two fixed fields:
A token ID field that identifies this token as an exec_env token
The remainder of this token is composed of zero or more null-terminated strings. The praudit command displays the exec_env token as follows:
exec_env,25, GROUP=staff,HOME=/export/home/matrix,HOST=mestrix,HOSTTYPE=sun4u,HZ=100, LC_COLLATE=en_US.ISO8859-1,LC_CTYPE=en_US.ISO8859-1,LC_MESSAGES=C, LC_MONETARY=en_US.ISO8859-1,LC_NUMERIC=en_US.ISO8859-1, LC_TIME=en_US.ISO8859-1,LOGNAME=matrix,MACHTYPE=sparc, MAIL=/var/mail/matrix,OSTYPE=solaris,PATH=/usr/sbin:/usr/bin,PS1=#, PWD=/var/audit,REMOTEHOST=192.168.13.5,SHELL=/usr/bin/csh,SHLVL=1, TERM=dtterm,TZ=US/Pacific,USER=matrix,VENDOR=sun |
The following figure shows the format of an exec_env token.
The exec_env token is output only when the audit policy arge is active.
The exit token records the exit status of a program. The exit token contains the following fields:
A token ID that identifies this token as an exit token
A program exit status as passed to the exit() system call
A return value that describes the exit status or that provides a system error number
The praudit command displays the exit token as follows:
exit,Error 0,0 |
The following figure shows the format of an exit token.
The file token is a special token that is generated by the audit daemon. The token marks the beginning of a new audit file and the end of an old audit file as the old file is deactivated. The audit daemon builds a special audit record that contains this token to “link” together successive audit files into one audit trail. The file token has four fields:
A token ID that identifies this token as a file token
A time and date stamp that identifies the time that the file was created or was closed
A byte count of the file name that includes a null terminator
A field that holds the file null-terminated name
The praudit command displays the file token as follows:
file,Tue Sep 1 13:32:42 1992, + 79249 msec, /var/audit/localhost/files/19990901202558.19990901203241.quisp |
The following figure shows the format of a file token.
This token has been replaced by the newgroups token, which provides the same type of information but requires less space. A description of the group token is provided here for completeness, but the application designer should use the newgroups token. Notice that praudit does not distinguish between the two tokens, as both token IDs are labeled group in praudit output.
The group token records the groups entries from the process's credential. The group token has two fixed fields:
A token ID that identifies this token as a group token
An array of group entries of size NGROUPS_MAX (16)
The remainder of the token consists of zero or more group entries. The praudit command displays the group token as follows:
group,staff,admin,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1 |
The following figure shows the format of a group token.
The group token is output only when the audit policy group is active.
The header token is special in that it marks the beginning of an audit record. The header token combines with the trailer token to bracket all the other tokens in the record. The header token has six fields:
A token ID field that identifies this token as a header token
A byte count of the total length of the audit record, including both the header and the trailer
A version number that identifies the version of the audit record structure
The audit event ID that identifies the type of audit event that the record represents
The ID modifier that identifies special characteristics of the audit event
The time and date that the record was created
On 64-bit systems, the header token is displayed with a 64-bit time stamp, in place of the 32-bit time stamp.
The praudit command displays the header token for a ioctl() system call as follows:
header,240,1,ioctl(2),es,Tue Sept 1 16:11:44 2001, + 270000 msec |
The following figure shows the format of a header token.
The ID modifier field has the following flags defined:
0x4000 PAD_NOTATTR nonattributable event 0x8000 PAD_FAILURE fail audit event |
The in_addr token contains an Internet Protocol address. Since the Solaris 8 release, the Internet address can be displayed in IPv4 format or IPv6 format. The IPv4 address uses 4 bytes. The IPv6 address uses 16 bytes to describe the type, and 16 bytes to describe the address. The in_addr token has two fields:
A token ID that identifies this token as an in_addr token
An Internet address
The praudit command displays the in_addr token as follows:
ip address,129.150.113.7 |
The following figure shows the format of an in_addr token.
The ip token contains a copy of an Internet Protocol header. The ip token has two fields:
A token ID that identifies this token as an ip token
A copy of the IP header, that is, all 20 bytes
The praudit command displays the ip token as follows:
ip address,0.0.0.0 |
The IP header structure is defined in the /usr/include/netinet/ip.h file. The following figure shows the format of an ip token.
The ipc token contains the System V IPC message/semaphore/shared-memory handle that is used by the caller to identify a particular IPC object. The ipc token has three fields:
A token ID that identifies this token as an IPC token
A type field that specifies the type of IPC object
The handle that identifies the IPC object
The praudit command displays the ipc token as follows:
IPC,msg,3 |
The IPC object identifiers violate the context-free nature of the Solaris audit tokens. No global “name” uniquely identifies IPC objects. Instead, IPC objects are identified by their handles. The handles are valid only during the time that the IPC objects are active. However, the identification of IPC objects should not be a problem. The System V IPC mechanisms are seldom used, and the mechanisms all share the same audit class.
The following table shows the possible values for the IPC object type field. The values are defined in the /usr/include/bsm/audit.h file.
Table 23–7 Values for the IPC Object Type Field|
Name |
Value |
Description |
AU_IPC_MSG |
1 |
IPC message object |
AU_IPC_SEM |
2 |
IPC semaphore object |
AU_IPC_SHM |
3 |
IPC shared-memory object |
The following figure shows the format of an ipc token.
The ipc_perm token contains a copy of the System V IPC access information. This token is added to audit records that are generated by IPC shared-memory events, IPC semaphore events, and IPC message events. The ipc_perm token has eight fields:
A token ID that identifies this token as an ipc_perm token
The user ID of the IPC owner
The group ID of the IPC owner
The user ID of the IPC creator
The group ID of the IPC creator
The access modes of the IPC
The sequence number of the IPC
The IPC key value
The praudit command displays the ipc_perm token as follows:
IPC perm,root,wheel,root,wheel,0,0,0x00000000 |
The values are taken from the ipc_perm structure that is associated with the IPC object. The following figure shows the format of an ipc_perm token.
The iport token contains the TCP or UDP port address. The iport token has two fields:
A token ID that identifies this token as an iport token
The TCP or UDP port address
The praudit command displays the iport token as follows:
ip port,0xf6d6 |
The following figure shows the format of an iport token.
This token replaces the group token. Notice that the praudit command does not distinguish between the two tokens, as both token IDs are labeled group in praudit output.
The newgroups token records the group entries from the process's credential. The newgroups token has two fixed fields:
A token ID field that identifies this token as a newgroups token
A count that represents the number of groups that are contained in this audit record
The remainder of this token is composed of zero or more group entries. The praudit command displays the newgroups token as follows:
group, staff, admin |
The following figure shows the format of a newgroups token.
The newgroups token is output only when the group audit policy is active.
The opaque token contains unformatted data as a sequence of bytes. The opaque token has three fields:
A token ID that identifies this token as an opaque token
A byte count of the data
An array of byte data
The praudit command displays the opaque token as follows:
opaque,12,0x4f5041515545204441544100 |
The following figure shows the format of an opaque token.
The path token contains access path information for an object. This token contains the following fields:
A token ID that identifies this token as an path token
A byte count of the path length
The absolute path to the object that is based on the real root of the system
The praudit command displays the path token as follows. Note that the path length field is not displayed.
path,/etc/security/audit_user |
The following figure shows the format of a path token.
The process token contains information about a user who is associated with a process, such as the recipient of a signal. The process token has nine fields:
A token ID that identifies this token as a process token
The invariant audit ID
The effective user ID
The effective group ID
The real user ID
The real group ID
The process ID
A terminal ID that consists of a device ID and a machine ID
The audit ID, user ID, group ID, process ID, and session ID are long instead of short.
The process token fields for the session ID, the real user ID, or the real group ID might be unavailable. The value is then set to -1.
Any token that contains a terminal ID has several variations. The praudit command hides these variations. So, the terminal ID is handled the same way for any token that contains a terminal ID. The terminal ID is either an IP address and port number, or a device ID. A device ID, such as the serial port that is connected to a modem, can be zero. The terminal ID is specified in one of several formats.
The terminal ID for device numbers is specified as follows:
32-bit applications – 4-byte device number, 4-bytes unused
64-bit applications – 8-byte device number, 4-bytes unused
The terminal ID for port numbers in releases that are earlier than the Solaris 8 release is specified as follows:
32-bit applications – 4-byte port number, 4-byte IP address
64-bit applications – 8-byte port number, 4-byte IP address
The terminal ID for port numbers in the Solaris 8 release or the Solaris 9 release is specified as follows:
32-bit with IPv4 – 4-byte port number, 4-byte IP type, 4-byte IP address
32-bit with IPv6 – 4-byte port number, 4-byte IP type, 16-byte IP address
64-bit with IPv4 – 8-byte port number, 4-byte IP type, 4-byte IP address
64-bit with IPv6 – 8-byte port number, 4-byte IP type, 16-byte IP address
The praudit command displays the process token as follows:
process,root,root,wheel,root,wheel,0,0,0,0.0.0.0 |
The following figure shows the format of a process token.
The return token contains the return status of the system call (u_error) and the process return value (u_rval1). This token has three fields:
A token ID that identifies this token as a return token
The error status of the system call
The return value of the system call
The return token is always returned as part of kernel-generated audit records for system calls. This token indicates exit status and other return values in application auditing.
The praudit command displays the return token as follows:
return,success,0 |
The following figures shows the format of a return token.
The sequence token, seq, is an optional token that contains a sequence number. Used for debugging, this token is added to each audit record when the seq policy is active. The seq token has two fields:
A token ID that identifies this token as a seq token
A 32-bit unsigned long field that contains the sequence number
The sequence number is incremented every time an audit record is generated and added to the audit trail. The praudit command displays the seq token as follows:
sequence,1292 |
The following figure shows the format of a seq token.
The seq token is output only when the seq audit policy is active.
The socket token contains information that describes an Internet socket. This token has six fields:
A token ID that identifies this token as a socket token
A socket type field that indicates the type of socket referenced, one of TCP, UDP, or UNIX
The local port address
The local Internet address
The remote port address
The remote Internet address
The praudit command displays the socket token as follows:
socket,0x0000,0x0000,0.0.0.0,0x0000,0.0.0.0 |
Since the Solaris 8 release, the Internet address can be displayed in IPv4 format or IPv6 format. The IPv4 address uses 4 bytes. The IPv6 address uses 16 bytes to describe the type, and 16 bytes to describe the address. The following figure shows the format of a socket token.
The subject token describes a user who performs or attempts to perform an operation. The format is the same as the process token. The subject token has nine fields:
An ID that identifies this token as a subject token
The real user ID
The real group ID
The process ID
The subject token fields for the session ID, the real user ID, or the real group ID might be unavailable. The value is then set to -1.
The subject token is always returned as part of kernel-generated audit records for system calls. The praudit command displays the subject token as follows:
subject,cjc,cjc,staff,cjc,staff,424,223,0 0 quisp |
The following figure shows the format of the subject token.
The text token contains a text string. This token has three fields:
A token ID that identifies this token as a text token
The length of the text string
The text string itself
The praudit command displays the text token as follows:
text,aw_test_token |
The following figure shows the format of a text token.
The two tokens, header and trailer, are special in that they distinguish the end points of an audit record and bracket all the other tokens. A header token begins an audit record. A trailer token ends an audit record. The trailer token is an optional token. The trailer token is added as the last token of each record only when the trail audit policy has been set.
If an audit record was generated with trailers turned on, the auditreduce command verifies that the trailer points back to the record header correctly. The trailer token supports backward seeks of the audit trail.
The trailer token has three fields:
A token ID that identifies this token as a trailer token
A pad number to aid in marking the end of the record
The total number of characters in the audit record, including both the header and trailer tokens
The praudit command displays the trailer token as follows:
trailer,136 |
The following figure shows the format of a trailer token.
Device allocation protects removable media from unauthorized use. You can require that a user allocate a device. You can deny a user permission to use a device. Such allocation measures can protect your site from loss of data, computer viruses, and other security breaches. The following section provides information about device allocation.
The components of the device-allocation mechanism are as follows:
The allocate, deallocate, dminfo, and list_devices commands. For more information, see Using the Device Allocation Commands.
The /etc/security/device_allocate file. See the device_allocate(4) man page.
The /etc/security/device_maps file. See the device_maps(4) man page.
A lock file in the /etc/security/dev directory for each allocatable device.
The changed attributes of the device-special files that are associated with each allocatable device.
Device-clean scripts for each allocatable device.
The device_allocate file, the device_maps file, and the lock files are local configuration files. These files are not administered as name service databases because tape drives, diskette drives, and printers connect to specific machines.
This section describes some of the options to the allocate, deallocate, and list_devices commands that are for use by administrators. Only root or a role of equivalent power can access these options. The commands are detailed on their respective man pages.
Table 23–8 Administrative Options to the Device Allocation Commands
An allocatable device is in the allocate error state if it is owned by user bin and group bin with a device-special file mode of 0100. If a user wants to allocate a device that is in the allocate error state, you can try to force the deallocation of the device. The deallocate command with the -F option forces deallocation. Or, you can use allocate -U to assign the device to the user. Once the device is allocated, you can investigate any error messages that appear. After any problems with the device are corrected, you must use the force option, -F to clear the allocate error state from the device.
You can examine the /etc/security/device_maps file to determine the device names, device types, and device-special files that are associated with each allocatable device. See the device_maps(4) man page. Device maps are created when you set up device allocation. A rudimentary device_maps file is created by bsmconv when the BSM is enabled. This initial device_maps file should be used only as a starting point. You can then augment and customize the device_maps file for your site.
The device_maps file defines the device-special file mappings for each device, which in many cases is not intuitive. This file allows various programs to discover which device-special files map to which devices. You can use the dminfo command, for example, to retrieve the device name, the device type, and the device-special files to specify when you set up an allocatable device. The dminfo command uses the device_maps file to report this information.
Each device is represented by a one-line entry of the form:
device-name:device-type:device-list
Lines in the device_maps file can end with a backslash (\) to continue an entry on the next line. Comments can also be included. A “#” makes a comment out of all subsequent text until the next newline not immediately preceded by a backslash. Leading and trailing blanks are allowed in any field.
Table 23–9 Description of Fields in a device_maps Entry
The following is an example of entries in a device_maps file for SCSI tape st0 and diskette fd0.
fd0:\ fd:\ /dev/fd0 /dev/fd0a /dev/fd0b /dev/rfd0 /dev/rfd0a /dev/rfd0b:\ . . . st0:\ st:\ /dev/rst0 /dev/rst8 /dev/rst16 /dev/nrst0 /dev/nrst8 /dev/nrst16:\ |
You can modify the device_allocate file to change devices from allocatable to nonallocatable, or to add new devices. A sample device_allocate file follows.
st0;st;;;;/etc/security/lib/st_clean fd0;fd;;;;/etc/security/lib/fd_clean sr0;sr;;;;/etc/security/lib/sr_clean audio;audio;;;*;/etc/security/lib/audio_clean |
You define which devices should be allocatable during initial BSM configuration. You can decide to accept the default devices and their defined characteristics, as shown in the preceding sample device_allocate file. Whenever you add a device to any machine after the system is up and running, you must decide whether to make the new device allocatable.
After installation, you can modify the entries for devices in the device_allocate file. Any device that needs to be allocated before use must be defined in the device_allocate file on each machine. Currently, cartridge tape drives, diskette drives, CD-ROM devices, and audio chips are considered allocatable. These device types have device-clean scripts.
XylogicsTM tape drives or Archive tape drives also use the st_clean script that is supplied for SCSI devices. You need to create your own device-clean scripts for other devices, such as modems, terminals, graphics tablets, and other allocatable devices. The script must fulfill object-reuse requirements for that type of device.
An entry in the device_allocate file does not mean that the device is allocatable, unless the entry specifically states that the device is allocatable. In the sample device_allocate file, note the asterisk (*) in the fifth field of the audio device entry. An asterisk in the fifth field indicates to the system that the device is not allocatable. That is, the system administrator does not require a user to allocate the device before it is used nor to deallocate it afterward. Any other string placed in this field indicates that the device is allocatable.
In the device_allocate file, you represent each device by a one-line entry of the form:
device-name;device-type;reserved;reserved;alloc;device-clean |
For example, the following line shows the entry for device name st0:
st0;st;;;;;/etc/security/lib/st_clean |
Lines in the device_allocate file can end with a “\” to continue an entry on the next line. Comments can also be included. A “#” makes a comment out of all subsequent text until the next newline not immediately preceded by a “\”. Leading and trailing blanks are allowed in any field.
The following table describes each field in the device_allocate file.
Table 23–10 Description of Fields in a device_allocate Entry
The device-clean scripts address the security requirement that all usable data be purged from a physical device before reuse. By default, cartridge tape drives, diskette drives, CD-ROM devices, and audio devices require device-clean scripts, which are provided. This section describes what device-clean scripts do.
Device allocation satisfies part of the object-reuse requirement. The device-clean scripts make sure that data that is left on a device by one user is cleared. The data is cleared before the device is allocatable by another user.
The st_clean device-clean script supports three tape devices. The supported tape devices are as follows:
SCSI 1/4-inch tape
Archive 1/4-inch tape
Open-reel 1/2-inch tape
The st_clean script uses the rewoffl option to the mt command to affect the device cleanup. For more information, see the mt(1) man page. If the script runs during system boot, the script queries the device. The script determines if the device is online. If the device is online, the script determines if the device has media in it. The 1/4-inch tape devices that have media in them are placed in the allocate error state. The allocate error state forces the administrator to clean up the device manually.
During normal system operation, when the allocate or deallocate command is executed in interactive mode, the user is prompted to remove the media. The script pauses until the media is removed from the device.
The following table shows the device-clean scripts for diskettes and CD-ROM devices.
Table 23–11 Device-Clean Scripts for Diskettes and CD-ROM Devices|
Disk Device Type |
Device-Clean Script |
Diskette | |
CD-ROM |
The scripts use the eject command to remove the media from the drive. See the eject(1) man page. If the eject command fails, the device is placed in the allocate error state.
Audio devices are cleaned up with an audio-clean script. The script performs an AUDIO_DRAIN ioctl system call to flush the device. The script then performs an AUDIO_SETINFO ioctl system call to reset the device configuration to the default. In addition, the script retrieves the audio chip registers by using the AUDIOGETREG ioctl system call. Any registers that deviate from the default settings are reset by using the AUDIOSETREG ioctl system call.
If you add more allocatable devices to the system, you might need to create your own device-clean scripts. The deallocate command passes a parameter to the device-clean scripts. The parameter, shown here, is a string that contains the device name. See the device_allocate(4) man page for more information.
st_clean -[I|F|S] device-name |
Device-clean scripts must return “0” for success and greater than “0” for failure. The options -I, -F, and -S help the script determine its running mode. The following table describes the options.
Table 23–12 Options for Device-Clean Scripts
This section gives an example of how the device-allocate mechanism works.
The allocate command first checks for the presence of a lock file under the device name for the specified device in the /etc/security/dev directory. If the file is owned by allocate, then the ownership of the lock file is changed to the name of the user who initiated the allocate command.
The allocate command then checks for an entry for the device in the device_allocate file. The command further checks that the entry shows that the device as allocatable.
The first listing in the following example shows that a lock file exists with owner bin, group bin, and mode 600 for the st0 device in /etc/security/dev. The second listing shows that the associated device-special files are set up properly, with owner bin, group bin, and mode 000.
untouchable% ls -lg /etc/security/dev/st0 -rw------- 1 bin bin 0 Dec 6 15:21 /etc/security/dev/st0 untouchable% ls -lg /devices/sbus@1,f8000000/esp@0,800000 c--------- 1 bin bin 18, 4 May 12 13:11 st@4,0: c--------- 1 bin bin 18, 20 May 12 13:11 st@4,0:b c--------- 1 bin bin 18, 28 May 12 13:11 st@4,0:bn c--------- 1 bin bin 18, 12 May 12 13:11 st@4,0:c . . . c--------- 1 bin bin 18, 0 May 12 13:11 st@4,0:u c--------- 1 bin bin 18, 16 May 12 13:11 st@4,0:ub c--------- 1 bin bin 18, 24 May 12 13:11 st@4,0:ubn c--------- 1 bin bin 18, 8 May 12 13:11 st@4,0:un |
In this example, the user vanessa allocates device st0.
untouchable% whoami vanessa untouchable% allocate st0 |
When the user vanessa runs the allocate command to allocate the tape st0, allocate first checks for the existence of an /etc/security/dev/st0 file. If no lock file exists or if the lock file is owned by a user other than allocate, then user vanessa could not allocate the device.
If the allocate command finds the lock file for the device with the correct ownership and permissions, the command then checks to make sure that the device has an entry in the device_allocate file. The command also checks that the entry specifies that the device is allocatable.
In this example, the default device_allocate entry for the st0 device specifies that the device is allocatable. Because the allocate command finds that all these conditions are met, the device is allocated to user vanessa.
The allocate command changes the ownership and permissions of the device-special files that are associated with the device in the /dev directory. To allocate the st0 device to the user vanessa, the mode on its associated device-special files is changed to 600 and the owner is changed to vanessa.
The allocate command also changes the ownership of the lock file that is associated with the device in the /etc/security/dev directory. To allocate the st0 device to the user vanessa, the owner of /etc/security/dev/st0 is changed to vanessa.
In the following example, after the user vanessa executes the allocate command with the device name st0, the owner of /etc/security/dev/st0 is changed to vanessa and the owner of the associated device-special files is now also vanessa. Lastly, user vanessa now has permission to read and write the files.
untouchable% whoami vanessa untouchable% allocate st0 untouchable% ls -lg /etc/security/dev/st0 -rw------- 1 vanessa staff 0 Dec 6 15:21 /etc/security/dev/st0 untouchable% ls -la /devices/sbus@1,f8000000/esp@0,800000 . . . crw------- 1 vanessa 18, 4 May 12 13:11 st@4,0: crw------- 1 vanessa 18, 12 May 12 13:11 st@4,0:b crw------- 1 vanessa 18, 12 May 12 13:11 st@4,0:bn crw------- 1 vanessa 18, 12 May 12 13:11 st@4,0:c . . . crw------- 1 vanessa 18, 4 May 12 13:11 st@4,0:u crw------- 1 vanessa 18, 12 May 12 13:11 st@4,0:ub crw------- 1 vanessa 18, 12 May 12 13:11 st@4,0:ubn crw------- 1 vanessa 18, 12 May 12 13:11 st@4,0:un |
