System Administration Guide: Security Services
The audit_control File
An /etc/security/audit_control file on each machine is read by the audit daemon. See the audit_control(4) man page. The audit_control file is located in the /etc/security directory. Each machine has its own local audit_control file. The file enables every machine to mount their audit file systems from different locations or in a different order. For example, the primary audit file system for machineA might be the secondary audit file system for machineB.
You specify four kinds of information in the audit_control file. Each line of information begins with a keyword.
An audit_control file is created during the configuration process on each machine.
When you make changes to the audit_control file, you then run the audit -s command to instruct the audit daemon to reread the file.
Note –
The audit -s command does not change the preselection mask for existing processes. Use auditconfig, setaudit, or auditon for existing processes. See the getaudit(2) and auditconfig(1M) man pages for more information.
Sample audit_control File
The following is a sample audit_control file for the machine dopey. dopey uses two audit file systems on the audit server blinken, and a third audit file system that is mounted from the second audit server winken. The third file system is used only when the audit file systems on blinken become full or unavailable. The minfree value of 20 percent specifies that the warning script is run when the file systems are 80 percent filled. The flags specify that logins and administrative operations are to be audited. The operations are audited for success and for failure. Failures of all types, except failures to create a file system object, are to be audited. Non-attributable events are also audited.
flags:lo,am,-all,^-fc
naflags:lo,nt
minfree:20
dir:/etc/security/audit/blinken/files
dir:/etc/security/audit/blinken.1/files
# Audit filesystem used when blinken fills up
dir:/etc/security/audit/winken
