Device allocation protects removable media from unauthorized use. You can require that a user allocate a device. You can deny a user permission to use a device. Such allocation measures can protect your site from loss of data, computer viruses, and other security breaches. The following section provides information about device allocation.
The components of the device-allocation mechanism are as follows:
The allocate, deallocate, dminfo, and list_devices commands. For more information, see Using the Device Allocation Commands.
The /etc/security/device_allocate file. See the device_allocate(4) man page.
The /etc/security/device_maps file. See the device_maps(4) man page.
A lock file in the /etc/security/dev directory for each allocatable device.
The changed attributes of the device-special files that are associated with each allocatable device.
Device-clean scripts for each allocatable device.
The device_allocate file, the device_maps file, and the lock files are local configuration files. These files are not administered as name service databases because tape drives, diskette drives, and printers connect to specific machines.
This section describes some of the options to the allocate, deallocate, and list_devices commands that are for use by administrators. Only root or a role of equivalent power can access these options. The commands are detailed on their respective man pages.
Table 23–8 Administrative Options to the Device Allocation Commands
An allocatable device is in the allocate error state if it is owned by user bin and group bin with a device-special file mode of 0100. If a user wants to allocate a device that is in the allocate error state, you can try to force the deallocation of the device. The deallocate command with the -F option forces deallocation. Or, you can use allocate -U to assign the device to the user. Once the device is allocated, you can investigate any error messages that appear. After any problems with the device are corrected, you must use the force option, -F to clear the allocate error state from the device.
You can examine the /etc/security/device_maps file to determine the device names, device types, and device-special files that are associated with each allocatable device. See the device_maps(4) man page. Device maps are created when you set up device allocation. A rudimentary device_maps file is created by bsmconv when the BSM is enabled. This initial device_maps file should be used only as a starting point. You can then augment and customize the device_maps file for your site.
The device_maps file defines the device-special file mappings for each device, which in many cases is not intuitive. This file allows various programs to discover which device-special files map to which devices. You can use the dminfo command, for example, to retrieve the device name, the device type, and the device-special files to specify when you set up an allocatable device. The dminfo command uses the device_maps file to report this information.
Each device is represented by a one-line entry of the form:
device-name:device-type:device-list
Lines in the device_maps file can end with a backslash (\) to continue an entry on the next line. Comments can also be included. A “#” makes a comment out of all subsequent text until the next newline not immediately preceded by a backslash. Leading and trailing blanks are allowed in any field.
Table 23–9 Description of Fields in a device_maps Entry
The following is an example of entries in a device_maps file for SCSI tape st0 and diskette fd0.
fd0:\ fd:\ /dev/fd0 /dev/fd0a /dev/fd0b /dev/rfd0 /dev/rfd0a /dev/rfd0b:\ . . . st0:\ st:\ /dev/rst0 /dev/rst8 /dev/rst16 /dev/nrst0 /dev/nrst8 /dev/nrst16:\ |
You can modify the device_allocate file to change devices from allocatable to nonallocatable, or to add new devices. A sample device_allocate file follows.
st0;st;;;;/etc/security/lib/st_clean fd0;fd;;;;/etc/security/lib/fd_clean sr0;sr;;;;/etc/security/lib/sr_clean audio;audio;;;*;/etc/security/lib/audio_clean |
You define which devices should be allocatable during initial BSM configuration. You can decide to accept the default devices and their defined characteristics, as shown in the preceding sample device_allocate file. Whenever you add a device to any machine after the system is up and running, you must decide whether to make the new device allocatable.
After installation, you can modify the entries for devices in the device_allocate file. Any device that needs to be allocated before use must be defined in the device_allocate file on each machine. Currently, cartridge tape drives, diskette drives, CD-ROM devices, and audio chips are considered allocatable. These device types have device-clean scripts.
XylogicsTM tape drives or Archive tape drives also use the st_clean script that is supplied for SCSI devices. You need to create your own device-clean scripts for other devices, such as modems, terminals, graphics tablets, and other allocatable devices. The script must fulfill object-reuse requirements for that type of device.
An entry in the device_allocate file does not mean that the device is allocatable, unless the entry specifically states that the device is allocatable. In the sample device_allocate file, note the asterisk (*) in the fifth field of the audio device entry. An asterisk in the fifth field indicates to the system that the device is not allocatable. That is, the system administrator does not require a user to allocate the device before it is used nor to deallocate it afterward. Any other string placed in this field indicates that the device is allocatable.
In the device_allocate file, you represent each device by a one-line entry of the form:
device-name;device-type;reserved;reserved;alloc;device-clean |
For example, the following line shows the entry for device name st0:
st0;st;;;;;/etc/security/lib/st_clean |
Lines in the device_allocate file can end with a “\” to continue an entry on the next line. Comments can also be included. A “#” makes a comment out of all subsequent text until the next newline not immediately preceded by a “\”. Leading and trailing blanks are allowed in any field.
The following table describes each field in the device_allocate file.
Table 23–10 Description of Fields in a device_allocate Entry
The device-clean scripts address the security requirement that all usable data be purged from a physical device before reuse. By default, cartridge tape drives, diskette drives, CD-ROM devices, and audio devices require device-clean scripts, which are provided. This section describes what device-clean scripts do.
Device allocation satisfies part of the object-reuse requirement. The device-clean scripts make sure that data that is left on a device by one user is cleared. The data is cleared before the device is allocatable by another user.
The st_clean device-clean script supports three tape devices. The supported tape devices are as follows:
SCSI 1/4-inch tape
Archive 1/4-inch tape
Open-reel 1/2-inch tape
The st_clean script uses the rewoffl option to the mt command to affect the device cleanup. For more information, see the mt(1) man page. If the script runs during system boot, the script queries the device. The script determines if the device is online. If the device is online, the script determines if the device has media in it. The 1/4-inch tape devices that have media in them are placed in the allocate error state. The allocate error state forces the administrator to clean up the device manually.
During normal system operation, when the allocate or deallocate command is executed in interactive mode, the user is prompted to remove the media. The script pauses until the media is removed from the device.
The following table shows the device-clean scripts for diskettes and CD-ROM devices.
Table 23–11 Device-Clean Scripts for Diskettes and CD-ROM Devices
Disk Device Type |
Device-Clean Script |
Diskette | |
CD-ROM |
The scripts use the eject command to remove the media from the drive. See the eject(1) man page. If the eject command fails, the device is placed in the allocate error state.
Audio devices are cleaned up with an audio-clean script. The script performs an AUDIO_DRAIN ioctl system call to flush the device. The script then performs an AUDIO_SETINFO ioctl system call to reset the device configuration to the default. In addition, the script retrieves the audio chip registers by using the AUDIOGETREG ioctl system call. Any registers that deviate from the default settings are reset by using the AUDIOSETREG ioctl system call.
If you add more allocatable devices to the system, you might need to create your own device-clean scripts. The deallocate command passes a parameter to the device-clean scripts. The parameter, shown here, is a string that contains the device name. See the device_allocate(4) man page for more information.
st_clean -[I|F|S] device-name |
Device-clean scripts must return “0” for success and greater than “0” for failure. The options -I, -F, and -S help the script determine its running mode. The following table describes the options.
Table 23–12 Options for Device-Clean Scripts
This section gives an example of how the device-allocate mechanism works.
The allocate command first checks for the presence of a lock file under the device name for the specified device in the /etc/security/dev directory. If the file is owned by allocate, then the ownership of the lock file is changed to the name of the user who initiated the allocate command.
The allocate command then checks for an entry for the device in the device_allocate file. The command further checks that the entry shows that the device as allocatable.
The first listing in the following example shows that a lock file exists with owner bin, group bin, and mode 600 for the st0 device in /etc/security/dev. The second listing shows that the associated device-special files are set up properly, with owner bin, group bin, and mode 000.
untouchable% ls -lg /etc/security/dev/st0 -rw------- 1 bin bin 0 Dec 6 15:21 /etc/security/dev/st0 untouchable% ls -lg /devices/sbus@1,f8000000/esp@0,800000 c--------- 1 bin bin 18, 4 May 12 13:11 st@4,0: c--------- 1 bin bin 18, 20 May 12 13:11 st@4,0:b c--------- 1 bin bin 18, 28 May 12 13:11 st@4,0:bn c--------- 1 bin bin 18, 12 May 12 13:11 st@4,0:c . . . c--------- 1 bin bin 18, 0 May 12 13:11 st@4,0:u c--------- 1 bin bin 18, 16 May 12 13:11 st@4,0:ub c--------- 1 bin bin 18, 24 May 12 13:11 st@4,0:ubn c--------- 1 bin bin 18, 8 May 12 13:11 st@4,0:un |
In this example, the user vanessa allocates device st0.
untouchable% whoami vanessa untouchable% allocate st0 |
When the user vanessa runs the allocate command to allocate the tape st0, allocate first checks for the existence of an /etc/security/dev/st0 file. If no lock file exists or if the lock file is owned by a user other than allocate, then user vanessa could not allocate the device.
If the allocate command finds the lock file for the device with the correct ownership and permissions, the command then checks to make sure that the device has an entry in the device_allocate file. The command also checks that the entry specifies that the device is allocatable.
In this example, the default device_allocate entry for the st0 device specifies that the device is allocatable. Because the allocate command finds that all these conditions are met, the device is allocated to user vanessa.
The allocate command changes the ownership and permissions of the device-special files that are associated with the device in the /dev directory. To allocate the st0 device to the user vanessa, the mode on its associated device-special files is changed to 600 and the owner is changed to vanessa.
The allocate command also changes the ownership of the lock file that is associated with the device in the /etc/security/dev directory. To allocate the st0 device to the user vanessa, the owner of /etc/security/dev/st0 is changed to vanessa.
In the following example, after the user vanessa executes the allocate command with the device name st0, the owner of /etc/security/dev/st0 is changed to vanessa and the owner of the associated device-special files is now also vanessa. Lastly, user vanessa now has permission to read and write the files.
untouchable% whoami vanessa untouchable% allocate st0 untouchable% ls -lg /etc/security/dev/st0 -rw------- 1 vanessa staff 0 Dec 6 15:21 /etc/security/dev/st0 untouchable% ls -la /devices/sbus@1,f8000000/esp@0,800000 . . . crw------- 1 vanessa 18, 4 May 12 13:11 st@4,0: crw------- 1 vanessa 18, 12 May 12 13:11 st@4,0:b crw------- 1 vanessa 18, 12 May 12 13:11 st@4,0:bn crw------- 1 vanessa 18, 12 May 12 13:11 st@4,0:c . . . crw------- 1 vanessa 18, 4 May 12 13:11 st@4,0:u crw------- 1 vanessa 18, 12 May 12 13:11 st@4,0:ub crw------- 1 vanessa 18, 12 May 12 13:11 st@4,0:ubn crw------- 1 vanessa 18, 12 May 12 13:11 st@4,0:un |
