The audit trail is created by the audit daemon. The audit daemon starts on each machine when the machine is brought up. After the auditd daemon starts at boot time, it is responsible for collecting the audit trail data and writing the audit records into audit files, which are also called audit log files. For a description of the file format, see the audit.log(4) man page. See also the auditd(1M) man page.
Even though you can physically locate audit directories within file systems that are not dedicated to auditing, do not do so except for directories of last resort. Directories of last resort are directories where audit files are written only when there is no other suitable directory available.
There is one other scenario where locating audit directories outside of dedicated audit file systems could be acceptable. You might do so in a software development environment where auditing is optional. To make full use of disk space might be more important than to keep an audit trail. However, in a security-conscious environment, audit directories within other file systems is not acceptable.
You should also consider the following factors.
A host should have at least one local audit directory. The local directory can be used as a directory of last resort if the host is unable to communicate with the audit server.
Mount audit directories with the read-write (rw) option. When you mount audit directories remotely, also use the intr and noac options.
List the audit file systems on the audit server where they reside. The export list should include all machines in the configuration.
