System Administration Guide: Security Services
Example—Changing the Soft Limit for Warnings
The minfree line in the audit_control file defines the minimum free-space level for all audit file systems. In this example, the soft limit is set so that a warning is issued when only 10 percent of the file system is available.
# cat /etc/security/audit_control
dir:/var/audit
flags:
minfree:10
naflags:lo
