System Administration Guide: Security Services
Example—Combining and Reducing Audit Files
Use the auditreduce command with the -O option to combine several audit files into one file and to save the files in a specified output file. auditreduce can do this type of combination and deletion automatically. See the -C and -D options in the auditreduce(1M) man page. However, you can select the files manually to good effect. Use the find command, then use auditreduce to combine just the named set of files.
When used in this way, the auditreduce command merges all the records from its input files into a single output file. The input files should then be deleted. In addition, the output file should be kept in a directory that is named /etc/security/audit/server-name/files so that auditreduce can find the output file.
# auditreduce -O combined-filename
The auditreduce command can also reduce the number of records in its output file. The command can eliminate the less interesting records as it combines the input files. For example, you might use the auditreduce command to retain only the login and logout records in audit files that are over a month old. If you need to retrieve the complete audit trail, you could recover the trail from backup tapes.
# auditreduce -O daily.summary -b 19990413 -c lo; compress *daily.summary
# mv *daily.summary /etc/security/summary.dir
