All systems that run the auditing subsystem should have a local file system that can be used if no other file system is available. In this example, a file system is being added to a system that is named egret. Since this file system is only used locally, none of the steps for a file server are followed.
# newfs /dev/rdsk/c0t2d0 # mkdir /var/audit/egret # grep egret /etc/vfstab /dev/dsk/c0t2d0s1 /dev/rdsk/c0t2d0s1 /var/audit/egret ufs 2 yes - # tunefs -m 0 /var/audit/egret # mount /var/audit/egret # mkdir /var/audit/egret/files # chmod -R 750 /var/audit/egret/files |
