System Administration Guide: Security Services
Adding an Allocatable Device (Task Map)
The following task map describes the major steps that are required to define a new allocatable device.
Task
Description
For Instructions
1. Create or change an entry in the device_allocate file
Defines which devices are controlled by the device-allocation mechanism.
How to Change Which Devices Can Be Allocated
2. Create a lock file
Enables the device allocation mechanism to work on a specific device.
How to Set Up Lock Files for an Allocatable Device
3. (Optional) Create a device-clean script
Purges data from a physical device.
Device-Clean Scripts
4. Allocate the device
Adds a device to the device-allocation mechanism.
How to Allocate a Device
5. (Optional) Deallocate the device
Removes a device from use.
How to Deallocate a Device
