System Administration Guide: Security Services
First Contact With the Server
The transmission, which includes the encrypted time stamp and the encrypted conversation key, is then sent to the server. The transmission includes a credential and a verifier. The credential contains three components:
The window is the difference in time that the client says should be allowed between the server's clock and the client's time stamp. If the difference between the server's clock and the time stamp is greater than the window, the server rejects the client's request. Under normal circumstances, this rejection does not happen, because the client first synchronizes with the server before starting the RPC session.
The client's verifier contains the following:
The window verifier is needed in case somebody wants to impersonate a user. The impersonator can write a program that, instead of filling in the encrypted fields of the credential and verifier, just stuffs in random bits. The server decrypts the conversation key into some random key. The server then uses the key to try to decrypt the window and the time stamp. The result is random numbers. After a few thousand trials, however, the random window/time stamp pair is likely to pass the authentication system. The window verifier makes the process of guessing the right credential much more difficult.
